Garage door opener - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 07-15-2013, 01:12 PM Thread Starter
TheMike's Avatar
Default Garage door opener
I have found and use Mo-Door openers for both my Victory's. In attempting to put their button through the blank switch right of the radio display, I destroyed both the blank and the push button switch on the Mo-Door.
I decided to research and find a replacement switch to go in the blank on the XCT. I found it.
It's an OFF-momentary-on switch and it looks exactly like a factory Victory switch. Same color, size, and feel, and sealed too.
It looks like It came on the bike from Vic and works perfectly.
EDIT: A short video showing the same thing as the pics:
2012 #20 NESS Vision DARKSIDE BABY!
Stage 1 w/D&D pipes + lots of Victory add ons. PC-V w/AT, Lloyd's intake, filter, ATS, & Variable Clutch.
2013 Bushtec Entourage in matching Ness color and graphics - See the PAINTED TO MATCH process
Wife rides a 2016 Gunner
LONGMONT COLORADO
TheMike is offline
post #2 of 15 (permalink) Old 07-15-2013, 01:16 PM
beast30's Avatar
Cool! Where did you find the switch?
2012 XC Imperial Blue/Blacked out, LLoyds filter, LLoyds timing wheel,
VM1 DR cams, PC5, LLoyds ECM, Big Gonzo, KM meat hook bars (internally wired), Conquest underdrive pulley, KM instrument bezels, JTD lowers with speakers, PBR300 amp with Polk 6.5, .40 cal cheese wedges, tinted turn and tail
beast30 is offline
post #3 of 15 (permalink) Old 07-15-2013, 01:17 PM
ccrainman's Avatar
I a little more info please or maybe a how to. part numbers would help or where you got the switch from. Looks very factory.
ccrainman is offline
post #4 of 15 (permalink) Old 07-15-2013, 02:29 PM Thread Starter
TheMike's Avatar
I spent hours and days trying to find the right part for the job. That's what these forums are for right? Help each other out?
so here you go. The switches are made by Otto. These are K1 models. The part number of the one I got for the garage door opener is: K1ABCAAAAA
Everything after the K1 means something on/about the switch. Lighted, rocker type, configuration etc.
Otto Switches
They can be made in any configuration with labels, lighted, etc.
Now what took so long for me is that there was only ONE to be had anywhere. I checked. That one was allocated to someone else who had 20+ ordered (and those were still a month out). I begged to ask that customer if I could have it and they agreed.
The trouble comes that minimum orders and quantities are the norm to get these made to order switches.
Because I wasn't making either of those requirements they sent me that ONE switch COD. It's normally about a $10 switch but I ended up having to pay $27 to get it in my hands. To me it was worth it.
What's kinda cool about these switches and company is that I'm tempted to replaced switches on my Ness Vision with backlit ones with the stock labeling on them. If you download their PDF on the above site you can see exactly what and how to order pretty much anything you can come up with.
Again, you have to go through one of their distributors though so it's not as simple as ordering a switch and waiting to get it. Hence the reason I was tempted to get something going myself. Order a bunch and set up a package deal for fellow Victory riders.
Anywho, there you go. Here is a pic of the actual switch as I got it.
LONGMONT COLORADO
TheMike is offline
post #5 of 15 (permalink) Old 07-15-2013, 02:43 PM Thread Starter
TheMike's Avatar
I added a short video to the initial post.
LONGMONT COLORADO
TheMike is offline
post #6 of 15 (permalink) Old 07-15-2013, 02:48 PM
bet you could of wired it into the headlight high low switch or even the turnsignal switch
post #7 of 15 (permalink) Old 07-15-2013, 02:50 PM
bnhender's Avatar
Originally Posted by TheMike View Post
The hell with it. That's what these forums are for right? Help each other out?
Here you go. The switches are made by Otto. These are K1 models. The part number of the one I got for the garage door opener is: K1ABCAAAAA
Otto Switches
Attachment 29417
If you go to the OTTO web page you can look up distributors. I found this for Texas:
http://www.mouser.com/ProductDetail/...BPT5hAyw%3d%3d
Says a minimum order is 1, cost is $0.85. BUT AN 8 WEEK LEAD TIME!!
Thanks for the resource though, I was looking for this type of switch a few months ago.
___________________________________
Bill
2012 Cross Roads (Sunset Red)
Stage 1 flash
Lloydz Air Filter
Lloydz Idle Control Valve
Lloydz Adjustable Timing Wheel
Freedom Performance True-Dual Exhaust
VM1-DR cams
O2 Sensors disconnected
21" Adrenaline Front Wheel
Cee Bailey 24" windscreen w/ lowers
Tachometer
Small Bullet Light Bar
LED Headlight
Grasshopper driver backrest
Victory passenger backrest
Chrome saddlebag rails
2017 Octane
Shorty pipes
Navasota, TX
bnhender is offline
post #8 of 15 (permalink) Old 07-15-2013, 03:04 PM Thread Starter
TheMike's Avatar
I have a quote from them right in front of me from last week. I think you missed a "1" on your cost. $10.85 each switch but you are correct on the lead time.
I called and spoke to every distributer on Otto's site. That's how I found the ONE that was out there even though it was allocated to another company.
An old saying that's done well for me in my life, "TRUST BUT VERIFY". You can trust my leg work but feel free to verify yourself. I'm happy with my results and may at some point order from someone more switches for my Victory's. I went through the above process only because I really screwed up the blank switch in the XCT and wasn't willing to rig up something or to leave it screwed up.
Sure, there are many ways to hook up a simple switch that simply closes a circuit. Still requires "rigging" and I hate to do that when there are ways such as adding a simple stock type switch into a spot already designed for it. Nothing to cut on the bike, nothing to short out, nothing to splice, nothing to mod. Simple, affective, and as good as any manufacture could produce.
LONGMONT COLORADO
TheMike is offline
post #9 of 15 (permalink) Old 07-15-2013, 03:14 PM
bnhender's Avatar
I have a quote from them right in front of me from last week. $10.85 each switch and you are correct on the lead time.
I called and spoke to every distributer on Otto's site. That's how I found the ONE that out there even though it was allocated to another company.
Yea, I screwed up the blank switch plug when I had to take it out of the bracket installing the Light Bar and HID headlight. Kinda tweaked the light bar switch too, but it will work Would be great to replace them both. Putting the garage door button in that space would be sweet.
Thanks again for the legwork, I looked around for about a week trying to find these things with no success. At least now I have a manufacturer's name.
Bill
Stage 1 flash
Lloydz Air Filter
VM1-DR cams
Tachometer
LED Headlight
2017 Octane
Shorty pipes
Navasota, TX
bnhender is offline
post #10 of 15 (permalink) Old 07-15-2013, 03:19 PM Thread Starter
TheMike's Avatar
Hey visionjohny, imagine having all 4 of your panel switches backlit. That would be cool eh? They (Otto) have the Hazard and driving light label markings but couldn't find a "grip" type or one that would work for the garage door. Still, tempting to maybe get some and see how they work. Only if the backlit wouldn't be too overwhelming at night. Want to see them but don't need peripheral light shining elsewhere.
Like the radio and cruise control controls. Would love them backlit.
LONGMONT COLORADO
TheMike is offline
