2012 Cross Roads Classic LE Analog Tach QUestion - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 07-15-2013, 03:28 PM Thread Starter
ditech's Avatar
Default 2012 Cross Roads Classic LE Analog Tach QUestion
So I go to my Vic dealer today for a warranty job to realign the drive belt, and replace the main circuit breaker to resolve a issue I was having with stalling. Everything was fixed and is now in order and I'm happy about that.
Problem however, I noticed on my ride home my analog tach neddle now does not work properly. Before, the needle would go up and down smooth following the RPM's. Now it goes up and down in a jerking motion kind of like a rachet.
So I turned around and went back and showed them. They said they never seen anything like this before. Told me the tach is defective, or the heat could be causing it. It is super hot here right now. They did order me a replacement tach should be here in a few days.
My question is, has anyone ever had this problem? Could it be related to the circuit breaker? Dealer says 2 issues are unrelated.
Other the the jerky tach, everything else is 100% with the bike. The digital tach on the speedo works fine to.
Thanks for any input.
ditech is offline
post #2 of 7 (permalink) Old 07-15-2013, 08:22 PM
merdinus's Avatar
No issues with mine and it's been hot here.
2012 Crossroads - Stage 1 Flash - D&D Exhaust - CR Analog Tachometer - Victory Light Bar - Cruise Control - Lock N Ride Passenger Backrest - Lower Air Controls - Dipstick Thermometer - CHROME - Front & Rear Fender Rails, Heel Toe Shifter, AN Billet Grooved Engine Badge Set, Cam Chain Adjustment Covers, Saddle Bag Rails, Ness Diamond Band Grips & Pegs, Victory Logo Mirrors, Tube Highway Bar and Clutch Arm Cover
merdinus is offline
post #3 of 7 (permalink) Old 07-16-2013, 08:16 AM
bnhender's Avatar
No issues here either. Been very warm in southeast Texas.
___________________________________
Bill
2012 Cross Roads (Sunset Red)
Stage 1 flash
Lloydz Air Filter
Lloydz Idle Control Valve
Lloydz Adjustable Timing Wheel
Freedom Performance True-Dual Exhaust
VM1-DR cams
O2 Sensors disconnected
21" Adrenaline Front Wheel
Cee Bailey 24" windscreen w/ lowers
Tachometer
Small Bullet Light Bar
LED Headlight
Grasshopper driver backrest
Victory passenger backrest
Chrome saddlebag rails
2017 Octane
Shorty pipes
Navasota, TX
bnhender is offline
post #4 of 7 (permalink) Old 07-16-2013, 09:39 AM
I have the same tach on an 04 KP with no issues in temps up to 126.
The timing is suspect. Just after getting work done it starts doing this. I would ask to put the old breaker back in to see if it starts working correctly again. If they have already sent the old breaker in, thrown it away, or the new tach still does it you will know the breaker is indeed the problem.
However; they could have simply loosened at connection near the breaker inadvertently so it might be worth a looksee around that part and wiggle stuff.
post #5 of 7 (permalink) Old 07-16-2013, 07:30 PM
irv
irv's Avatar
mine started acting weird last fall. dealer got me another.
so far so good. it was readig about 1-1/2 the rpms you
were really revving.
mph faster].
irv is offline
post #6 of 7 (permalink) Old 07-16-2013, 11:58 PM
You are best advised to take it back to the dealer. They screwed it up, they should fix it. Taking a survey here isn't going to get it fixed. BTW, mine is working fine too.
You could open your headlight nacelle and locate the tach connector to see if it plugged in firmly.
post #7 of 7 (permalink) Old 07-17-2013, 04:30 PM
Luciferiad's Avatar
power surge coulda cooked a resistor in the head unit of the tach.
At work we just bought a guy a new instrument cluster for his Alero because a power surge during a battery service fried his. GMs and their fragile gauges
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
