Santa Rosa VT +2" Bars-brake mount - Victory Forums - Victory Motorcycle Forum
post #1 of 1 (permalink) Old 07-21-2013, 09:31 AM Thread Starter
Default Santa Rosa VT +2" Bars-brake mount
I have purchased some of the SRVT +2" bars. They were previously used on an '11 XC and he said they fit fine. The bars are definitely wider (OD-OD). The issue I am running into on my '13 XC is fitting the brake stuff on the bar. When I go to put the brake reservoir on the handlebar it contacts the bar on the "down" part and will not sit level. I tried to adjust a little, but it will not fit and it gets cocked quite a bit. If I raise the forward part of the reservoir it fits a little sideways but it makes the brake pull awkward. The SRVT bars have a much shorter grip area than the stock bars and that is causing the issue. The overall width also makes for a very tight fit when putting the fairing back on.
Has anyone had this issue and how did you overcome it?
Scott.
Virginia Beach, VA 23462
U.S. Navy, Nuc CWO, Submarines!!!
Upgraded from my 2013 Red Cross Country:
Red '17 Cross Country
Tank/Fairing Pinstripes by Brian Kite Pinstriping
HotVic exhaust
Victory Beveled Rider/Pass Floorboards
Victory Beveled Clutch/Brake/Heel Shifter Operators
Black Brake/Clutch Levers
Lloydz timing +4
Witchdoctor Red Braided Spark Plug Wires
Witchdoctor: relocated ignition key, small insert
Backrest
Luggage rack
Tour windshield
Vic oil dipstick with thermometer
sltpkirkland is offline
