2010 vs 2011 Cross Roads: Differences? - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 07-23-2013, 07:40 AM Thread Starter
KingpinRider's Avatar
Default 2010 vs 2011 Cross Roads: Differences?
Thinking of buying a used Cross Roads, just don't really know if there are any major changes between the 2010 and 2011 years. What significant changes are there between these years?
2008 Vision Tour Premium - Midnight Cherry
2008 Kingpin Tour - Black & Chrome (SOLD 10/14)
KingpinRider is offline
post #2 of 11 (permalink) Old 07-23-2013, 11:17 AM
In '11 Victory "updated" the transmission. Between mine and a friends '10 we can discern no difference.
The '11 model had Cruise control standard and a narrower seat. Leather bags were an option. Other than that......pretty much the same.
jmlmjmjm is offline
post #3 of 11 (permalink) Old 07-23-2013, 11:21 AM
If you are thinking about a trunk later on, the '10 requires and "up fit" kit the '11 does not. If I remember correctly, the '10 had the windshield and hard bags standard, also.
2011 CrossRoads
D&D pipes, PCV, Llyodz performance filter w/strip in place, Llyod's timing wheel (set +4) and various other visual do dads. :cool:
vagabondjpm is offline
post #4 of 11 (permalink) Old 07-23-2013, 11:29 AM
CrossRoads's Avatar
As mentioned there was a transmission tweak on the 2011's. The upgrade resulted in oil changes being required every 5000 miles on 2011's instead of every 2500 miles on the 2010's.
The instrument cluster was also upgraded on the 2011.
CrossRoads is offline
post #5 of 11 (permalink) Old 07-23-2013, 11:31 AM
irv
irv's Avatar
what they said. 2012 got no cruise, but abs.thats why i have
a 2011. 11000 miles later im still pretty happy. i think alsd the
'11s went to a 5000 mile oil change from 2500 on the 10s.
i still change at 3. either way you cant go wrong-
mph faster].
irv is offline
post #6 of 11 (permalink) Old 07-23-2013, 01:50 PM Thread Starter
Found this listing of changes for the 2011 Cross lineup in Motorcycle.com: http://www.motorcycle.com/manufactur...ews-89872.html
2011 Victory Upgrades
* A totally re-worked 6-speed transmission that promises smoother shifting, easier neutral access, 100,000-mile durability, and 5000 mile oil changes.
* New instruments for cruisers and Cross Roads. An analog speedo is joined by an LCD panel that includes a clock, gear-position indicator and numeric tach. It is backlit by a cool blue hue.
* Warning lights now in the gauge pack rather than inserted in the triple clamp
* New gear-position indicator that uses a calculation to determine which gear has been selected
* New 48-amp charging system across all models, with increased output at low revs
* Black switchgear housings
* New sidestands that are less bulky but easier to access
I believe 2011 started the build-your-own Cross Roads with bag and bar selections.
Thanks for all the other replies.
post #7 of 11 (permalink) Old 07-23-2013, 08:58 PM
Not mentioned above, or stated incorrectly about the 2010.....
+ Warning lights were in the instrument pod, not on the triple tree.
+ Instrument lighting is blue.
+ Saddle the same as all XCs with wide passenger portion.
+ Has black switchgear.
+ Hard cases, crash bar, windshield all standard.
post #8 of 11 (permalink) Old 07-25-2013, 06:39 PM Thread Starter
Thanks for the reminder on passenger seating. Remember the 2010 to 2011 transition and how I was disappointed with 2011 seating.
post #9 of 11 (permalink) Old 07-25-2013, 08:50 PM
CrossRoads's Avatar
How were you disappointed? Were you making the switch from being a passenger on a 2010 XR to being a passenger on a 2011 XR?
Surely everyone's butt is different, but when the 2011's came out, I had my wife sit on both passenger seats, without knowing which is which, and I asked her which she preferred. She chose the 2011 seat. Again, it's not better or worst, it's just what fits better with your passenger's bottom.
post #10 of 11 (permalink) Old 07-26-2013, 06:31 AM
irv
irv's Avatar
used xc seats are available if needed and there are now
aftermarket alternatives for your seating pleasure. i tried an xc
seat and now have an ultimate. both rider and passenger are
happy. also adj pass boards for the wife. fits either bike.
mph faster].
irv is offline
