CC Skidplate info - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 07-26-2013, 11:31 AM Thread Starter
Default CC Skidplate info
Anyone using this and have info or want to sell one?
Reasons for considering skidplate - I live off a gravel road and makes using the skidplate to lift bike easier...
if you have input or want to sell or recommend one maker over anothers?
2012 Cross Country Tour - VroomHilda
Dobeck EJK Gen3 Fuel Tuner
Tri Flo Ovals
Vic K&N knock off Air filter
Lloyds Timing Wheel +2
Relocated Air Shock fill hose
WD SkidPlate reinforced
Hyper running/brake lights
Garmin GPS
Existential Secular Humorist with warrior Buddhist leanings
*Rider/Owner continuous since 1973 - 877,000+ miles USMC R
SemperVee is online now
post #2 of 7 (permalink) Old 07-26-2013, 04:22 PM
irv
irv's Avatar
witchdoctors has one and also a video on installing it.
mph faster].
irv is offline
post #3 of 7 (permalink) Old 07-26-2013, 06:35 PM
sparkyo1's Avatar
i put one on my 12 XR that I got from HMD520. the holes did not line up so I had to bore them out so I could get the 4 bolts in. Not really a big deal but the part is rather pricing in my opinion so I would expect a little better quality. No experience on the one from Witchdoc but I would think most likely from an outside source since they look the same. Again, not bad-mouthing anyone just be aware!
RIDE SAFE!
2013 XC ANTI-FREEZE GREEN
Tomball Tx.
sparkyo1 is offline
post #4 of 7 (permalink) Old 07-26-2013, 07:24 PM Thread Starter
RIDE SAFE!
Thanks for the info... How well does it work when using with bike on a MC lift? Any experience there?
Tri Flo Ovals
Garmin GPS
post #5 of 7 (permalink) Old 07-26-2013, 07:30 PM
Others have said it works well with the lift. Much easier. I have one I haven't put on yet. Too many other things with a higher priority right now.
I can tell you it's heavy. I doubt many would feel it being so low on the bike but it may effect gas mileage slightly.
post #6 of 7 (permalink) Old 07-26-2013, 11:16 PM
sparkyo1's Avatar
it is heavy and works great with a lift or jack. being flat on the bottom makes it more stable while lifted......
Tomball Tx.
sparkyo1 is offline
post #7 of 7 (permalink) Old 07-28-2013, 02:06 PM
I've got it mounted on mine, makes no differance on gas mileage. It took all of 30 mins to install with the help of my jack to get the holes lined up. It does help with the lifting of the bike however you will still find its best to remove the trunk before lifting.
Joseph
2012 XCT (HOOPTIE)
joseph is offline
