Aux Brake lights on XR - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 08-01-2013, 12:32 PM Thread Starter
Default Aux Brake lights on XR
Finally installed my LED 's to rear of bike. It definitely adds to visual appearance at night as well as during the day.
bobcat5540 is offline
post #2 of 10 (permalink) Old 08-01-2013, 12:42 PM
CrossRoads's Avatar
That looks great. Perfect spot to install them.
CrossRoads is offline
post #3 of 10 (permalink) Old 08-01-2013, 01:26 PM
Did you make them special or is it a kit? Looks great!
post #4 of 10 (permalink) Old 08-01-2013, 10:52 PM
Weeds's Avatar
And were did you tap into for power....
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #5 of 10 (permalink) Old 08-02-2013, 09:51 AM Thread Starter
I purchased them from a place in Ca. GR Customs. There made by Knight Riderz mine were 7" long 21 led's (they also have 4" long )and come with strong double sided tape. I made simple brackets bent in a vice. Bolted to rear bag frame.I have some other pics I can send you.
post #6 of 10 (permalink) Old 08-02-2013, 10:00 AM Thread Starter
I removed seat and disconnected plug that connects to tail light, Used a meter to find which color was running and brake then used 3m splice adapter. Pretty easy. It took longer to decide where to mount them than it did to wire.
post #7 of 10 (permalink) Old 08-02-2013, 10:18 AM Thread Starter
The fact that its a brake light and not blinkers,no need for any load equalizers.
post #8 of 10 (permalink) Old 08-03-2013, 03:26 PM Thread Starter
Here's a picture of the LED bracket and location on frame.
post #9 of 10 (permalink) Old 08-03-2013, 09:40 PM
BenD's Avatar
Great job! I may have to steal your idea!
2012 XC Tour, Sunset Red/Silver PC-5 Thrush mod pipes Lloydz air filter and timing wheel.
California Sidecar Trike Conversion
Phoenix, AZ
BenD is offline
post #10 of 10 (permalink) Old 08-05-2013, 08:25 AM
I mounted a set of LED pods on the bracket just above where you are pointing to in the picture. They fit perfect and are wired up for brake and turn.
You are correct in stating that the additional lights makes a big difference. Plus it is a great spot to mount them.
Billy
2014 XC
2006 Vegas 8 Ball
2014 Harley FLHTP (Keeping service techs busy)
Billyrides is offline
