Stage 1 flash - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 08-02-2013, 03:17 PM Thread Starter
rickster's Avatar
Default Stage 1 flash
If you just go mufflers and high flow do you need the stage 1 download
2012 Victory Cross Country Tour Pearl White
"You know your in trouble when the drums stop beating"
rickster is offline
post #2 of 6 (permalink) Old 08-02-2013, 03:20 PM
saddlebag's Avatar
No, but it will likely run better and last longer if you do that or some other form of fuel mapping correction for the new parts.
2011 Cross Roads
saddlebag is offline
post #3 of 6 (permalink) Old 08-02-2013, 03:32 PM
doing a flash will add fuel and advance your timing by 2 or 3 degrees.
Check your mileage now. Add your air filter and exhaust and see if your mileage changes.
If you think your lean un hook your 02's that will get you richer.
You will get popping but if you don't close the throttle all the way when you shift you can avoid the popping.
No I don't think the flash is worth the 100 or so bucks
post #4 of 6 (permalink) Old 08-02-2013, 04:42 PM Thread Starter
rickster's Avatar
Thanks I haven't done anything yet but I see alot of stage 1 mufflers for sale and would like my stock XCT to have a little more rumble. I'm leaning on the Llyodz air filter as well.
rickster is offline
post #5 of 6 (permalink) Old 08-02-2013, 05:17 PM
Tims_04V92TC's Avatar
.......If you think your lean un hook your 02's that will get you richer.
+1 on the O2's if ANY popping ONCE you have checked all joints for torque and seated. See LLoydz technote on Popping. Very good. It's a simple fix and it works. throttle roll off technique is just the way it is, you will figure it out.
Stage1 flash. +1 Don't waste your money. The VFCIII is EASY to install, it is an addon so your not doing anything but unplugging your fuel injectors and plugging them into the VFCIII and then the VFCIII into the injector. You can email Lloydz for a baseline set of numbers to use or someone here can maybe help too with your configuration. Unbelieveable improvement I see them on here for around 200 used or 265 new I think.
As for the air filter, a must. EPA kills what these engines are capable of WITHOUT major work. More air, more gas and better exhaust unleash what you already paid for AND provides MILES of SMILES!
Good luck and keep us posted!
Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #6 of 6 (permalink) Old 08-02-2013, 05:51 PM
save your money on a flash and spen it on Lloydz V111
best money you could spend
