just changed the oil on the x.c. and - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 01-27-2011, 06:16 PM Thread Starter
Default just changed the oil on the x.c. and
I think I put to much in. Its barely above the top line......should I let some out? TIA.
rking35209 is offline
post #2 of 13 (permalink) Old 01-27-2011, 06:34 PM
bigseadaddy's Avatar
If it is just barely I think you will be fine but I am sure Kevin will jump in.
Navy Chief! Navy Pride!
2010 Victory CrossRoads - Factory Skulls
2008 Softail Deluxe - Black/Copper (SOLD)
2005 Victory Kingpin - Black (SOLD) :(
2003 Yamaha 1100 VStar - Silver/White (SOLD)
2000 Suzuki Hayabusa (or GSX1300R) (STILL RIDE)
1999 Yamaha R6 - Blue (TOTALED)
1992 Honda CBR600 - Black (SOLD)
bigseadaddy is offline
post #3 of 13 (permalink) Old 01-27-2011, 07:04 PM
bfp
bfp's Avatar
Did you start it let it run then shut it off let it sit for a couple minutes then check it?
2010 cross roads Custom
2015 Ness Magnum
2016 Magnum X1 Custom
2013 Vision Custom
bfp is offline
post #4 of 13 (permalink) Old 01-27-2011, 07:08 PM
Start it let it run a couple then shut it down, wait a few and re-check it....sometimes have to let it run through the filter...How much did you put in it....? Check that against what your manual states on capacity....
Paul M is offline
post #5 of 13 (permalink) Old 01-27-2011, 07:21 PM
kevinx's Avatar
Your fine a tad above the line won't cause you any grief
kevinx is offline
post #6 of 13 (permalink) Old 01-27-2011, 07:22 PM
Roadrocket's Avatar
How much did you put in? Did you change the filter as well?
Roadrocket is offline
post #7 of 13 (permalink) Old 01-27-2011, 08:28 PM Thread Starter
4.5 qts, yes I changed the filter and yes I ran it for about 3 min even ran it around the block.
post #8 of 13 (permalink) Old 01-27-2011, 10:00 PM
CrossRoads's Avatar
I thought it takes 5 quarts. So you didn't shake the bike up and down for every drop of old oil to come out?
CrossRoads is offline
post #9 of 13 (permalink) Old 01-28-2011, 09:42 AM
Ok - from the "did you plug it in?" help desk....
Are you checking the oil while the bike is upright and not on the side stand? That's how to check the oil in these bikes.
Sorry if it's obvious. Never appreciated that piece of engineering. Checking the oil shouldn't require two people, a center stand or a lift.
AustinTx-LT is offline
post #10 of 13 (permalink) Old 01-28-2011, 10:42 AM
07PEARLJACKPOT's Avatar
i use a 4"x4" block under the kickstand to level the bike.
KURYAKYN LED BLINKERS
GUNFIGHTER SEAT
KURYAKYN FLAME COMFORTGRIPS
KURYAKYN FLAME PEGS
"JACKPOT" OIL COOLER COVER
CHROME STARTER COVER
MEMPHIS SHADES WINDSHIELD
VICTORY TOOL ROLL
RPW SLASH EXHAUST
S&S INTAKE
KURYAKYN ELLIPSE MIRRORS
07PEARLJACKPOT is offline
