Oil Pressure Indicator Light Stays On - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 08-14-2013, 03:10 PM Thread Starter
Tuffy's Avatar
Default Oil Pressure Indicator Light Stays On
I have a '13 XCT with about 2600 mls. When I switch off the motor and then turn the key off, the oil pressure indicator stays on for about 10 - 15 seconds. I know this sounds strange, but it has be doing this since around 500 miles. They tell me this can't happen because when you turn the key off it cuts the power, but it happens. However, it doesn't happen all the time.
Has anyone else experienced this issue?
2013 XCT - Black
Klock Werks Flare Windsheild
HID Headlight
Tri-Oval Stage 1 Exhaust
K&N Air Filter
K&P Engineering Oil Filter
Ness Chrome Finned Engine Covers
Chrome Fender Rails
Tuffy is offline
post #2 of 13 (permalink) Old 08-14-2013, 03:27 PM
if you pull oil switch you'll see a hole in it. When the bike is running oil will go up the hole and put out the light. When there is no oil then the light stays on.
Pull switch and shot some cab cleaner up it or take it to auto store and get new one for around 5 bucks.
If there is a rubber boot on oil switch take it off it will trap water and mud.
Should be a simple fix
post #3 of 13 (permalink) Old 08-14-2013, 04:50 PM
steviej's Avatar
mine has always done that but I would say for not more than 3-5 seconds after the key is turned off.
steviej
steviej is offline
post #4 of 13 (permalink) Old 08-14-2013, 05:28 PM
Pckrfan's Avatar
mine does too intermitantly... my 2011 never did that
2013 AG-XC:
Gustafsson +2 Euro Flip
JWSpeaker 8695 LED Headlight
Ma Vic (Black Tri-Ovals/S1 Package, pull backs, derby covers,
heated seat, bag bars, shorty antennae)
Ness Rad III mirrors, Avon heated grips, Wolo Bad Boy air horn
RICZ's LD PL8 bracket and lotsa blacked out stuff
GOODY'S fork mounted lowers (3M'd)
Bag graphics & inner fairing, Bad Boys Design Peoria, AZ.
Artificial intelligence is absolutely 100% NO MATCH...............for natural stupidity!
Pckrfan is offline
post #5 of 13 (permalink) Old 08-14-2013, 09:29 PM
I have a 2012 XC and my light has done this since it had 4 miles on it. About 5 or so seconds after I shut it off.
tdees98 is offline
post #6 of 13 (permalink) Old 08-14-2013, 10:55 PM
Mine will stay on for 2 or 3 seconds sometimes; especially if the engine is hot (above 85* outside temp).
orbiker is offline
post #7 of 13 (permalink) Old 08-15-2013, 01:55 AM
Weeds's Avatar
Now i have to go check it out ....
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #8 of 13 (permalink) Old 08-15-2013, 05:20 AM
I noticed it exactly one time on my XCT but that doesn't mean it hasn't done it since
post #9 of 13 (permalink) Old 08-17-2013, 08:47 AM
Camo's Avatar
2011 CC here. My oil light will stay on only if I kill the engine with the handlebar switch, leaving the key on briefly. Shut the key off and the light stays on for a few seconds. If I kill the engine with the key, it never happens.
2008 Hammer Custom - Sold
2011 Cross Country
Camo is offline
post #10 of 13 (permalink) Old 08-17-2013, 09:11 AM
Lostintexas's Avatar
My 12 does it. ABS light does strange things too. The only Vic tech I can find, and he is weak, says they do it. As long as they don't stay on running or off. Owners manual says they both stay on for a bit, ABS until under way isn't cause for alarm.
Nothing seems broke so why lose sleep over it. BTW, there has been plenty of electrical problems with mine, but these seem wide spread and a harmless quirk.
YMMV
I ride with the Force.
Lostintexas is offline
