IPod problems - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 03-07-2011, 04:47 AM Thread Starter
dirtdobber's Avatar
Default IPod problems
Went for a ride several days ago and the IPod did not come on. Had to turn it on manually (by the IPod itself). Now if I stop for fuel it comes on like it did. After about 1 hour I have to turn it on manually. The IPod was purchased just for the XC, so it is almost new. checked all connectors. It seems the bike is not charging the battery.
any ideas
2011 Cross Country
If everything fails read the instructions
dirtdobber is offline
post #2 of 13 (permalink) Old 03-07-2011, 11:08 AM Thread Starter
dirtdobber's Avatar
Okay I found that the IPod is charging. Must be something with the extension or IPod plug.
When the switch is turned off the IPod turns off like normal but when the switch is turned on the IPod is not getting a signal.
Later on I will hook up the IPod with the plug directly to the connector in the fairing.
This should tell 1 of 3 things, Bad extension or radio malfunction or IPod plug.
2011 Cross Country
post #3 of 13 (permalink) Old 03-07-2011, 01:13 PM
warr110r's Avatar
Let us know...My Ipod started acting a little funny the other day. I have not had a chance to trouble shoot yet though.
2011 Blue Cross Country
Arlen Ness RAD III Mirrors
Bassani 4" Mufflers
Stablemate:
2002 Yamaha Warrior
110 C.I. Patrick Racing Kit
Waay too many other Mods
warr110r is offline
post #4 of 13 (permalink) Old 03-07-2011, 03:10 PM Thread Starter
dirtdobber's Avatar
Mine started last week, at first it would lose it's conductivity and go off and I would have to reset it with the controls on the bars by going to FM and then back to the IPod.
2011 Cross Country
post #5 of 13 (permalink) Old 03-07-2011, 03:54 PM
CrossRoads's Avatar
Default Reset IPOD to factory defaults.
While I don't run an IPod on my bike, I have had similar problems with my IPod. I believe these are known issues with the Ipod power connectivity. If you don't have your Ipod customized to a point where you don't want to change anything, try resetting it to factory defaults and see if that eliminates the problem. It fixed my IPod connectivity problem, and it might fix it for you as well. This might be a good thing to try before you go any further.
CrossRoads is offline
post #6 of 13 (permalink) Old 03-07-2011, 04:19 PM Thread Starter
dirtdobber's Avatar
I will try that. It's simplest to do anyway.
thanks
2011 Cross Country
post #7 of 13 (permalink) Old 03-07-2011, 06:37 PM Thread Starter
dirtdobber's Avatar
That did not work, but I did get my music like I wanted in the first place. Wednesday I will pull the fairing and hook it directly to the input.
2011 Cross Country
post #8 of 13 (permalink) Old 03-07-2011, 07:24 PM
My ipod works but it is a classic and it freezes once in awhile. I have to pad it to keep the vibrations down.
2011 CROSS COUNTRY
pdsmith is offline
post #9 of 13 (permalink) Old 03-07-2011, 08:16 PM Thread Starter
dirtdobber's Avatar
I have not had any problems until my cable got caught on my belt and cut the cover and 1 wire into. soldered back together and it works good except I have to turn it on manually, by the ipod itself every time it sits for 30 minutes or so. When it turns itself off. Short stops it works fine.
I will figure it out, We have some more rain coming so I will have time Wednesday to pull the fairing and connect it directly to the connection. I am sure it is the extension.
I'm going to Birmingham tomorrow so I might see if they have 1 in stock.
2011 Cross Country
post #10 of 13 (permalink) Old 03-08-2011, 09:42 AM
CrossRoads's Avatar
Ahhh, I agree with your suspicion then: new cable needed. Possibly the connection where you soldered is not making a good enough contact, or maybe it just doesn't conduct the same electrical impulse the wire can conduct.
