XC Max tire size - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 40 (permalink) Old 03-10-2011, 06:12 PM Thread Starter
gumper800's Avatar
Default XC Max tire size
Anyone know if a 200 will fit????
2011 Cross Country
gumper800 is offline
post #2 of 40 (permalink) Old 03-10-2011, 06:18 PM
CrossRoads's Avatar
I'm sorry, I don't know. But I must ask, why would you?
A fat tire is usually for show, but on the Cross Country, the only eyes seeing your rear tire are the ants on the ground. Do you have some other reason I'm not seeing? Or are you planning on chopping off the rear fender to show the fatter tire?
CrossRoads is offline
post #3 of 40 (permalink) Old 03-10-2011, 06:41 PM Thread Starter
gumper800's Avatar
i will go faster
2011 Cross Country
post #4 of 40 (permalink) Old 03-10-2011, 07:18 PM
dirtdobber's Avatar
Due to the rim size I do not think it would look any larger than a 180. according to bridgestone the 200 requires a 6.0-6.5 width rim. Avon cobra 200 requires a 5.5 inch rim. Not sure if it would clear everything.
2011 Cross Country
If everything fails read the instructions
dirtdobber is offline
post #5 of 40 (permalink) Old 03-10-2011, 07:19 PM
ammo_umb's Avatar
Why??? Do you realize that a wide rear tire is going to mess with your handling? You don't really think a 200mm tire is going to make you bike faster do you? 200mm is the width; wider tires aren't "faster" -- wider tires are just wider...
Retired USAF, IYAAYAS!
ammo_umb is offline
post #6 of 40 (permalink) Old 03-10-2011, 07:30 PM
if you were to put the 200 vs the stock size on a scale, you would find the 200 weighs about 4lbs more...greater mass= greater rotational drag= slower roll on times.
I watch alot of guys with busa's put a 240 to a 300 on the rear, thinking it looks cool....on the dyno they loose 15-20rwhp and upwards of 10 ft/lbs of tq.
9secondsflat is offline
post #7 of 40 (permalink) Old 03-10-2011, 07:37 PM
dirtdobber's Avatar
There isn't much difference in height of the 2 tires.
180/70x16 or 200/60x16
2011 Cross Country
post #8 of 40 (permalink) Old 03-10-2011, 09:11 PM
bryman's Avatar
I found this thread hilarious. Is it April 1st?
The Cross bikes hide the rear tire so well that it would be nearly impossible to tell the difference without getting down on your knees. Heck, I'm having a hard time trying to figure out how I'm going to check the air in the rear tire without taking a bag off!
You would only lose handling and performance by changing to a 200 on this bike.
Also OT - anyone notice the HD ad that pops up every time you hover over the word "Cross Country" on this website? Coincidence - I think not. Those HD marketing geniuses are working overtime and getting nervous.
Current Bike: 2011 Victory Cross Roads - Crimson
Options and Accessories:
Victory: Stage 1 / Forged Bars w/pegs / Medium Windshield / Lowers / Hard Bags w/ Guards / Passenger Backrest / XC Passenger Floorboards / Heated Grips / Unlocked Speedo w/ temp probe
Other: Signal Dynamic LED Plate frame w/BackOff XP / Clearwater Glenda LED Lights / 3BRPowersports USB in-bag power port / Utopia police backrest w/quick-out / D&D Boss slip-ons (569-12F)
bryman is offline
post #9 of 40 (permalink) Old 03-11-2011, 02:20 PM
warr110r's Avatar
Well here is a topic that I actually have prior knowledge, so please allow me to throw my 2 cents in.
My 2002 Yamaha Warrior comes stock with a 200. If you know the warrior then you know that it is built for cornering, in the cruiser world. I ruined the outsides of a pair of boots at the Dragon and had a blast doing it.
Now when I did my engine upgrades I found that I was ripping through tires in less than 3000 miles without burnouts. It wasn't due to the 107 Hp but more due to the 127 ft lbs of torque. Of course the only part of the tire that was worn was the center contact patch. Basically I had about an inch and a half worn down to the belt. So at the advice of friends from another forum I upgraded to a 240 back wheel and tire. This was to increase the life of the tire by improving the size of the contact patch width.
Here is what I learned;
Yes there is a loss of Hp. More so with mine because the wheel and tire were bigger = more weighted mass to turn.
No there was no real handling difference on that bike. I had trusted friends who had stock warriors swap with me and they said only at first could you tell the difference.
Yes it improved the life of the tire. I now get more than 5000 miles on a tire which is better then I got when the bike was all stock. In fact I went with a Conti Race attack tire because it was more sticky.
Now what will the tire do for this bike? Probably not too much. Like the warrior, this bike handles beautifully so you will probably not notice too much there. You will lose a little Hp due to the weight of the tire, more so if you get a wider rim. You might find that by going with a wider tire on the stock rim you actually reduce the contact patch and reduce the life of the tire. That was another lesson learned with the warrior. IMPO you would have to look way up her skirt to see that there is a wider tire in there.
So will it fit? From what DD says it doesn't sound like it.
I personally would only put a wider tire on if I were to do major Hp upgrades and I promised myself that I wouldn't do that.
But it is your bike so if you do it, just make sure you post pictures so we can gawk at them.
I'll shut up now....
2011 Blue Cross Country
Arlen Ness RAD III Mirrors
Bassani 4" Mufflers
Stablemate:
2002 Yamaha Warrior
110 C.I. Patrick Racing Kit
Waay too many other Mods
warr110r is offline
post #10 of 40 (permalink) Old 03-11-2011, 02:22 PM
Actually it's a very good question and one I'd like to know the answer to as well. Mostly because I'm probably going to go darkside on my first rear tire change. If a 195 will fit; I'll have a lot more choices to choose from. Right now I'm planning to go with a 175 van tire that has worked out very well on many HD Softail's.
By the way, if you use Firefox and the Adblock Plus addon, you won't see the pop up ad's in the forum's.
