Air Filter Foam Strip - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 04-12-2011, 03:12 PM Thread Starter
rsmarsh's Avatar
Default Air Filter Foam Strip
I'm going to modify my Stage 1 exhaust pipes with the 1 1/8" hole per the instructions several of you have given in this forum. My question is this. Does the fuel tank have to be completely removed in order to access the "foam strip" that many of you have removed to help improve air intake or can you simply loosen it from the front and lift it up enough. Thanks again all your help guys!!!!!
2010 Crossroads
Crimson Red
Extreme Cycle Sound System
LED Lights w/FX module
Passanger Backrest
Stage 1 Performance
Lloydz RPW V-211 Pipes
KewlMetal Flame Exhaust Tips
Arlen Ness Holeshot Grips/Pegs/Engine Covers
rsmarsh is offline
post #2 of 5 (permalink) Old 04-12-2011, 03:24 PM Thread Starter
rsmarsh's Avatar
Default Sorry Guys
I'm new to the Victory Forums site and didn't realize until after I posted this question that you could search the forums for pretty much anything. Anyway, I did a search and this question has already been asked and answered so thanks again to everyone who helps and provides input.
2010 Crossroads
Crimson Red
Passanger Backrest
Stage 1 Performance
rsmarsh is offline
post #3 of 5 (permalink) Old 04-12-2011, 05:35 PM
The Diamond
diamondrmp's Avatar
diamondrmp is offline
post #4 of 5 (permalink) Old 04-12-2011, 05:43 PM
PhilC64's Avatar
If you have the Stage 1 pipes you DO NOT need to take anything to it. The exhaust on a Stage 1 pipe is 1.75 inch diameter and is a straight through design. You 1 and 1/8th bit won't do a thing except chew up the interior.
PhilC64 is offline
post #5 of 5 (permalink) Old 04-13-2011, 07:31 AM Thread Starter
rsmarsh's Avatar
Thanks Phil. I appreciate the heads up before I went out and purchased what I needed. You da Man!
2010 Crossroads
Crimson Red
Passanger Backrest
Stage 1 Performance
rsmarsh is offline
