X Bike Heat Shields - BBob - Page 3 - Victory Forums - Victory Motorcycle Forum
 3Likes
post #21 of 38 (permalink) Old 11-16-2013, 02:03 PM
Originally Posted by Chili View Post
Agree with everything said in the last two posts. I wouldn't hesitate to recommend the product, just figured if Bob was looking to continue to tinker I'd try slightly larger.
Maybe I should make it an option. What do you guys think? Standard and XL?
Heck; everything is an option as far as I'm concerned. I just want to get as close to what the customer wants as I can.
Wally, after thinking about it a bit, I'm not sure the ABS plastic would last any longer than the leather. Maybe even not as long. Steel or an alloy would though. Unlike a seat; the shields don't get stretched and stressed so the cracks may never show if some routine maintenance is given at the same time as other surfaces of the bike. The resolene acrylic I apply when done making them should last quite a while. Anyone could continue using it or Super Sheen acrylic from time to time or switch to a leather conditioner or water proofing.
BBob is online now
post #22 of 38 (permalink) Old 11-17-2013, 12:11 PM
Can anyone tell me if these help as far as reducing the heat thats directed to the passengers feet?
Joseph
2012 XCT (HOOPTIE)
joseph is offline
post #23 of 38 (permalink) Old 11-17-2013, 12:20 PM
Originally Posted by arkiebiker View Post
OKIt's the nature of the bike (you ARE sitting on an engine)...all TOURING bikes have this problem.
I dont find that to be true, unless you dont feel Goldwings and BMWs are touring bikes. Even in the vtwin world this is the hotest bike Ive ever riddin. While others are in shorts in 112 degree heat ridding their harleys I couldnt dream of it. Its not something I would do but that isnt the point of the message.The point is they can and do. I dont know about the Cross country or the cross roads but the tour model really deep fries your legs and the feet of the passenger. I have got to find a way to direct the heat away from her feet. As it is in any temps over 85 degrees I cant get enough air flow to her feet to keep them from cooking.
Joseph
2012 XCT (HOOPTIE)
joseph is offline
post #24 of 38 (permalink) Old 11-17-2013, 01:07 PM Thread Starter
arkiebiker's Avatar
Not gonna argue with you because I can't speak to the BMW. But the Goldwing has the same complaints (maybe not to the same degree, no pun intended)...but there are complaints about the heat in the box. Same for the Ultra's.
Here's my setup...maybe it will help you. I have the Ultimate seat and that HELPS. I have the Victory seat pad and that HELPS. I run regular gas and that HELPS. I have Bob's heat shields, and that HELPS. I keep my vents CLOSED at all times, and that HELPS. You put all those things together and on VERY hot days I am no more uncomfortable than anyone else on a hot day.
Maybe some of those tips can help you.
Motorbikerx likes this.
Searcy, AR
Blytheville, AR (Hometown and the BEST BBQ Sandwiches in the world)
Arkansas Bikers Website
http://www.arkansasbiker.net
Garmin Zumo GPS Forums
http://www.zumoforums.com
arkiebiker is offline
post #25 of 38 (permalink) Old 11-17-2013, 01:30 PM
I could ride all day long on wing wearing shorts and the only burn I got was a sun burn. Same goes on a beamer. The reason being on a wing the heat is directed back toward the rear tire. Ive ridden the harleys and they were damn hot but not as hot on the legs as the vic. I assume air flow has a lot to do with it.
Anyway, not sure how a seat changes the heat to your legs or the feet of the passenger? I need more information to understand how it works? Also how does a seat pad keep heat off your legs? As far as the vents being kept closed I cant say Ive had the experiance of less air flow keeping my legs cooler. I know opening diff amounts can change things but if i close them completely I might as well be a oscar myer wiener because Im roasted. Hence why Im very hopeful these shields will help. No question Bob has a very reasonable price and from what I have seen the best design to date. I"m really hoping they might help direct the heat away from my passengers feet.
Joseph
2012 XCT (HOOPTIE)
joseph is offline
post #26 of 38 (permalink) Old 11-17-2013, 05:02 PM
I think it does help, Joseph, because airflow is caught by the skirt of the shield and directed downward where it exits much lower. What happens for the passenger is the heat still goes rearward (it has to go somewhere), is mixed with the cylinder head heat and the ambient air and creates a flow down around the passengers boot soles where it isn't felt like it would be if it was hitting in the shin area.
Maybe Arkie or others can get a passenger to feel the air flow to see if they are getting the same results...
BBob is online now
post #27 of 38 (permalink) Old 11-18-2013, 09:08 AM
BOB, once your back in full swing I will order one. I would like to buy one with the navy embossed. No rush on my end, back surgery is serious business, take your time and heal up right.
Joseph
2012 XCT (HOOPTIE)
joseph is offline
post #28 of 38 (permalink) Old 01-05-2014, 08:36 AM
BigMike45's Avatar
Bob,
Once have recovered from your surgery I would like to order a heat shield with Navy embossed on it.
Mike
2013 Black Victory Cross Country Tour
21" Magnum rim
Arlen Ness beveled shifter
Arlen Ness beveled heel shifter
Arlen Ness beveled brake arm
Arlen Ness shifter/brake pegs
HID High/Low
Lloyds timing wheel
Lloyds air filter
Arlen Ness Big Honkers
Custom Tribal graphics
Madstad shield
USN/LCDR LDO
BigMike45 is offline
post #29 of 38 (permalink) Old 01-05-2014, 08:46 AM Thread Starter
arkiebiker's Avatar
Nice piece of work too...
Searcy, AR
post #30 of 38 (permalink) Old 01-05-2014, 10:21 AM
I think I can start making them again. I will make the changes needed on the website today.
Thanks for all the support guys and girls!!
BBob is online now
