Dang Oil Leak - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 11-05-2013, 05:49 PM Thread Starter
sthxc83's Avatar
Default Dang Oil Leak
Well, I have the infamous oil leak from the rear head on my '13 XC. Twice now, I have wiped up oil from the top of the transmission case and from the fins under the exhaust port on the rear head. Closer inspection and it looks to be either a head gasket or the porous head issue. Snow is flying now, so spring I'll find out what the dealer says. Kind of leaves a sour taste in my mouth...haven't even put 1,000 of my own miles on the damn thing and I am seeing leaking. I guess the silver lining is that it happened before my warranty is up in June.
Mike
2013 Nuclear Sunset XC - VicBagger Tarzan Bars, Gus +2 Euroflip, Goody Fork Lowers, Atom Bomb Exhaust, Lloydz Timing Wheel, Adjustable Lowering Link, VicBagger Tips, Kuryakyn ISO Grips, Ricz plate bracket.
Past Rides:
2004 Yamaha Roadstar Warrior
2003 Yamaha V-Star 650
sthxc83 is offline
post #2 of 19 (permalink) Old 11-06-2013, 11:49 AM
is your blow by hose hooked up? It might have come off and thats where your getting your oil from
post #3 of 19 (permalink) Old 11-06-2013, 01:30 PM
sgtduke's Avatar
Agree! check your hose at the top, my hose was fine but the little plastic 90 it goes into had cracked. Took the broken one to NAPA and the parts guys found a Ford part made out of rubber that was a perfect fit. I can't remember the part # though.
2014 Anniversary Edition Cross Country Tour #110
Touring Cams, PCV, Performance Air Filter,
Adjustable Timing System, D&D's Un-Baffled,
120hp/114tq (Installed by Kyle)
2012 Victory Cross Country Tour Pearl White (Totaled)
Drop in Cams, VFC III, First Gen Air Filter, Stage 1 pipes, 110hp/107tq (installed by Kevinx)
Vice President "Chesapeake Bay Victory Riders"
sgtduke is offline
post #4 of 19 (permalink) Old 11-06-2013, 04:52 PM Thread Starter
sthxc83's Avatar
That is actually the first thing I checked. The hose on both ends was secure, but I did not check for cracks in the fitting. I'll have to take a closer look at that. Thanks for the pointer!
Mike
Past Rides:
sthxc83 is offline
post #5 of 19 (permalink) Old 11-06-2013, 09:02 PM
Kuchera89's Avatar
Wouldnt you rather trailer it and get it fixed now rather than loose riding time when the weather gets nice?
2007 Hammer S 100CI
S&S air cleaner, PCIII, SRVT clubs exhaust, Avon grips.
2006 Kingpin 100CI
stage 1, touring setup to come soon...nm bought a XC.
2013 Sunset red and black XC
Kuchera89 is offline
post #6 of 19 (permalink) Old 11-06-2013, 09:25 PM
necoachbw's Avatar
I agree I would trail it and get it fixed now.
Nebraska
2014 Tequila Gold Cross Country
necoachbw is offline
post #7 of 19 (permalink) Old 11-07-2013, 06:31 AM
"Infamous"? I've maybe heard of this 3 or 4 times out of thousands of Victory's sold and used. Hardly "infamous". Go look on the net at some of the "infamous" problems other manufacturers have with their products. Anything that is mass produced has some possibility of un-forseens. Get it fixed under warranty, be happy and GO RIDE.
40XC is offline
post #8 of 19 (permalink) Old 11-07-2013, 09:02 AM
bsbabcock's Avatar
So there's potential a new head is in order? ..time for cams while you're there.
2013 Hard-Ball - Lloydz VM1-DR cams, air filter, timing wheel, PCV, properly tuned at KMC
Master, Biltmore Lodge #446, AF&AM
bsbabcock is offline
post #9 of 19 (permalink) Old 11-07-2013, 12:07 PM
What makes you think trailer?
Its 31 degrees and the roads are dry here in Minnesota
post #10 of 19 (permalink) Old 11-07-2013, 07:47 PM
Kuchera89's Avatar
He said snow was starting in the first post. Im in Texas so I dont know what snow entails for yall. Here ill just not ride for a day if it snows, it'll probly 80 degrees the next day
2007 Hammer S 100CI
2006 Kingpin 100CI
