Stage 1 Air Filter Issue - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 11-09-2013, 05:10 PM Thread Starter
saddlebag's Avatar
Default Stage 1 Air Filter Issue
So I moved the trunk back and removed the air filter to clean it today. I made some modifications to the filter retainer to flow more air and it was positively filthy on the top and just standard fithy toward the bottom. Much different then after it first cleaning having been run mostly in its stock configuration, it was relatively clean and at the time I noted I probably could have gone 20k between changes. Not anymore.
So anyway, after I clean it up and oil it, I notice several tiny places where the gauze filter element appear to have disolved leaving tiny holes. This does not make homey happy. A K&N it's not.
So I'm wondering if I can order a Stage 1 filter without ordering the whole damn Stage 1 kit. If I can't or it's prohibitively expensive, off to Lloyd's I go.
2011 Cross Roads
saddlebag is offline
post #2 of 13 (permalink) Old 11-09-2013, 05:43 PM
dope_man_21's Avatar
I dunno about the filter you have, but if you have the time you can cruise the K&N website and more than likely find one that they make that will match what you have.
$20,000 and 3000 miles DO NOT make you a biker
2013 Victory HighBall
Patriot Guard #156315
dope_man_21 is offline
post #3 of 13 (permalink) Old 11-09-2013, 05:44 PM
TNXR's Avatar
You can just order the S1 filter, I think it is 60 bucks or so.
2011 Cross Roads Sunset Red
TNXR is offline
post #4 of 13 (permalink) Old 11-09-2013, 05:56 PM
CrossRoads's Avatar
I'm confused. What filter do you have right now?
Keep in mind that the Stage 1 filter often comes rusty out of the box.
CrossRoads is offline
post #5 of 13 (permalink) Old 11-09-2013, 06:09 PM
dtmmil's Avatar
I believe he has a cross bike and as far as i know k&n doesnt make one for it. I do also believe you can just order the filter, but in my opinion the lloydz is the way to go.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #6 of 13 (permalink) Old 11-09-2013, 07:25 PM Thread Starter
saddlebag's Avatar
Yes.
I've had many K&Ns and never seen one do this. I don't have a problem with the metal mesh rusting though, just a cheap gauze element that seems to be self destructing.
I think I've accomplished the same thing by elimating the retainer material and the bike runs great. But if the damn filter element is going to be falling apart every 20k miles, I'll look elsewhere.
2011 Cross Roads
post #7 of 13 (permalink) Old 11-10-2013, 10:17 AM
dtmmil's Avatar
Sorry your probably better then factory but if you hold the lloydz next to the other you will see the difference, and the lloydz eliminates the plastic retainer all together. If you could see 2 bikes side by side, one with each filter you could see the difference, its hard to picture, especially with my explanation! haha However right out of the 2012 vic parts book here is the part number for the hi performance filter which i believe is what you have #2878041. what are you going to do with your old one if you replace?
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #8 of 13 (permalink) Old 11-10-2013, 12:34 PM Thread Starter
saddlebag's Avatar
I'll keep my retainer, but trash the filter. Thanks for the replacement p/n.
The Lloyd's also has a cone sectioned shape that blocks air from entering the intake directly. I instead must go around from the sides. If you could have seen the way mine got dirty, you'd see that the vast majority of air was taking a direct path to the intake via the top of the filter. My plastic retainer is filed very low. By far, the biggest obstruction between the fuel tank and the filter is the bolt head that tacks down the filter retainer.
2011 Cross Roads
post #9 of 13 (permalink) Old 11-10-2013, 12:41 PM
dtmmil's Avatar
I may be interested in the filter if you are trashing it. No problem on the number, i think it was $59.99 also. His filter has a much greater surface area for intake, its not so much about the directness of the flow but the volume, there is plenty of available air for it to suck in so it coming straight in the front is not so important.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #10 of 13 (permalink) Old 11-11-2013, 09:23 AM
slickvic's Avatar
Default Confused ?
With the gains offered using the Lloyds filter even on a stock bike, why would you go back to a stage 1 ? Especially now that it is deteriorating. I say go Lloyds.
slickvic is offline
