Oil Cooler T-Stat?? - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 05-31-2011, 10:55 AM Thread Starter
Default Oil Cooler T-Stat??
Does anybody know of an explanation for why the factory didn't incorporate a thermostat into the oil cooler? Simply curious and think this could only be beneficial for a faster warm up.
2011' Cross Country BLACK
PCV with AT
Bassani 2/1 Road Rage pipe (black)
Lloydz AF, IAV & Timing gear set at +4*
Heated Grips, Heated Seat
Saddlebag bumpers
2012 XCT Windshield
Kicker spkrs. #51525
HMD XC bars 33"
HIDs(crossroads)
1985 HD FXRT 93" (Keeper)
1998 Buell S1W 1203 (sold)
1984 HD XLS 1000 (sold)
1979 Yamaha XLS 750 (sold)
VIC11CC is offline
post #2 of 18 (permalink) Old 05-31-2011, 01:21 PM
RonBou's Avatar
I have never seen a thermastat for an oil cooler. Enlighten me. I would think on an air cooled bike the oil will get to operating temp pretty quickly and the oil cooler is just to keep it from getting too hot.
Ron
2012 Victory Cross Country Tour (Stage 1)
2011 Victory Cross Country (traded in on XCT)
2009 Triumph Rocket III Touring (traded in on XC)
1998 Valkyrie Tourer (Hydralocked - sold as is)
1966 Honda 305 Dream (for sale)
1967 Honda 305 Scrambler (project)
1982 Honda CB900 Custom (need to put back together)
RonBou is offline
post #3 of 18 (permalink) Old 05-31-2011, 01:36 PM
kevinx's Avatar
Pretty much covers it right there.
kevinx is offline
post #4 of 18 (permalink) Old 05-31-2011, 03:07 PM
Harley Davidson factory oil coolers have a thermostat that activates at 185 degrees. I guess they have it for a quicker oil warm for winter or real cold conditions if you' r going to take a quick trips around town durring those conditions. Saw a Victory U Tube video that said they had to reduce the original size of their oil cooler due to engine oil not getting to desired temp under the same mentioned conditions.
2011 Cross Country
Lloydz HOH-VM1-DR Cams
Arlen Ness Big-Shot 2 P/N 18-627
Performance Air Filter
D&D exhaust
Gustafsson +4 Shield
I POD
Adjustable lowering Link
Kicker PS52504 Speakers
Titan Amp BT454
08 VTX1800F sold
06 1200R Sportster sold
1979 Yam 750 Special sold
simpletruth is offline
post #5 of 18 (permalink) Old 05-31-2011, 03:28 PM Thread Starter
Most any after market oil cooler that you can purchase has the option of buying a t-stat with it. Lockhart is a mfg. that comes to mind. I've also seen riders put a hood over the oil cooler in cold temps to help the oil reach proper operating temps.. Just an option for more consistent oil temps. for an extended riding season I would figure.
PCV with AT
Saddlebag bumpers
2012 XCT Windshield
HMD XC bars 33"
HIDs(crossroads)
VIC11CC is offline
post #6 of 18 (permalink) Old 05-31-2011, 04:49 PM
kevinx's Avatar
HD and Star/Yami are both dry sump systems that operate at relativly low pressure. They NEED to warm the oil up in order for it to flow properly. Vic is a wet sump that operates at around 80psi constant, and our oil flows hot or cold against a gearator pump
kevinx is offline
post #7 of 18 (permalink) Old 06-01-2011, 02:31 AM
RonBou's Avatar
I guess I have learned something today. Plus... some bikes do have thermastats for the oil cooler. I feel much smarter now!
Ron
RonBou is offline
post #8 of 18 (permalink) Old 06-01-2011, 11:03 AM
Donzo's Avatar
I would like to see an oil pump fan - that turns on when the motor gets to a specified high temp. I something like this available? Do you guys think it would help in keeping the temp under control?
Donzo is offline
post #9 of 18 (permalink) Old 06-01-2011, 11:21 AM
There are a couple of ways you can go on this. Oil cooler fan or what is commonly called a Parade Fan.
http://bigskyfan.tripod.com/
post #10 of 18 (permalink) Old 06-01-2011, 11:39 AM
Donzo's Avatar
Thanks for the link. I checked it out, but there are no clear pics of how big the oil cooler fans are, wondering if they will fit - do you know anyone that has put this on a Vic?
Donzo is offline
