Speed sensor not working for stereo? - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 06-01-2011, 10:16 AM Thread Starter
toejam's Avatar
Question Speed sensor not working for stereo?
Upgraded the speakers in my XC to some Kenwood 5.25" coaxials and the speed sensor isn't raising the volume with increased speeds above the 15% mark on the volume indicator - any thoughts on what to do? (I got the 4 ohm to match the factory ones, and made sure that there were no cross overs on them)
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #2 of 10 (permalink) Old 06-01-2011, 08:04 PM
gulliverstoe's Avatar
howdy
no comments on your problem...my speed sensor works...although sometimes it does not go down at stops....very rare...
now then...how much better do your new speakers sound? worth it?
Tucson
2010 XCountry
gulliverstoe is offline
post #3 of 10 (permalink) Old 06-02-2011, 09:35 AM Thread Starter
toejam's Avatar
Sound is much better - Kenwood KFC-X133's vs. puny stock, no comparison. Cost was $86.24
BadBoy Horn, PCV
2006 Hammer - Gone
toejam is offline
post #4 of 10 (permalink) Old 06-02-2011, 11:17 AM
You have a sensor for your radio?
Tell me more very interesting.
post #5 of 10 (permalink) Old 06-02-2011, 01:04 PM
Have you checked to see if the setup for your radio still has the speed sensing/volume option set?????
Maybe disconnecting the OEM speakers caused the unit to reset that setting to "OFF".
Phideaux
2011 XC
2005 VTX 1800R Spec II
Phideaux is offline
post #6 of 10 (permalink) Old 06-02-2011, 07:57 PM
thanks toe....how was the install...i reckon they fit ok....drop right in?...
and ditto the comment on checking you control bit for speed sense on.
Tucson
2010 XCountry
post #7 of 10 (permalink) Old 06-02-2011, 09:16 PM
He's talking about the speed sensitive volume control. On the XC, it has 3 levels of volume increase. I use it on high and it seems to work perfect at raising volume to match wind and road noise.
Lattimer is offline
post #8 of 10 (permalink) Old 06-03-2011, 08:40 AM
Just this morning I was looking at another forum searching for info on speaker upgrade for my 11 XC. The information I got states that the oem is a 2 ohm and not a 4 ohm. The 4 ohm in a 2 ohm system will lose power and thus produce less sound. There were several threads for this so it was not just one guys opinion.
jacktrash is offline
post #9 of 10 (permalink) Old 06-03-2011, 09:18 AM
Makes sense. The stereo probably has a protection circuit that won't let it turn the volume up any higher with the additional load.
Does anybody have actual spec's on the stock speakers?
Lattimer is offline
post #10 of 10 (permalink) Old 06-03-2011, 09:30 AM
found my own answer. Speaker lists as follows:
POLARIS 4012273 SPKR-5.25",4OHM
Hmmmmmm.
Lattimer is offline
