Basic Heat Question - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 01-05-2014, 10:11 AM Thread Starter
Default Basic Heat Question
I have been reading quite a few posts recently and see a lot mentioned about XCT heat issues. Previously I owned a 2011 Vision Tour and put over 16K miles on her in two years. I had the OEM adjustable lowers on her. I never had any issue with heat for me or any passenger I might be carrying. I live in southern AZ and have ridden in some pretty hot temps and never felt uncomfortable. With that said, why is the XCT any different? It is the same power plant. Is it because of the air management system on the XCT? I'm just not understanding I guess. I am thinking seriously about getting a XCT but am concerned with the heat issue you all are mentioning.
2014 Victory XC - Suede Silver w/Flames
2013 BMW R1200RT - Crashed & Totaled
2011 Vision Tour - Sold
2008 Kawasaki Vulcan 900LT Classic - Traded In
1987 Kawasaki ZL1000 Eliminator - Sold
Visionary1963 is offline
post #2 of 15 (permalink) Old 01-05-2014, 10:19 AM
I think I can answer this. It's mostly an issue with the stock lowers like found on the Tour model. They kind of hold the heat in because they work so well in keeping the elements off the legs. There are ways to deal with it. Some more expensive than others.
I'm surprised you never felt uncomfortable in our AZ Summer heat on your Vision. The Vision is well known for being hot in the Summer. You might not have any issue with an XCT Tour because of this. You might simply be acclimated to the heat.
post #3 of 15 (permalink) Old 01-05-2014, 10:22 AM Thread Starter
BBob, thanks for the quick reply. For some reason I knew you would be the first responder. Lol. I kind of figured it was the lowers. But the Vision had pretty good protection as well and I don't remember ever being uncomfortable. Maybe my memory is shot but I don't think I did. I was reading the posting about your heat shields which is why I brought this up. I'm not averse to a heat shield just a little concerned it might be needed.
post #4 of 15 (permalink) Old 01-05-2014, 10:55 AM
I have 2013 xct and road with a passenger down to Houston Tx in the month of August. The average temp was about 100 deg. While fully loaded and averaging about 85 down the interstate the bike did fine with no issues to report. I felt a small amount of heat with the lowers open, but the passenger did not feel anything. The extra speed helped keep us cooler and the heat on my legs was not bad. After about 10 minutes on the bike, I did not notice the heat at all. When riding slow on city streets, I did not notice the heat at all. I guess it is being blown a different path. I would not worry about any heat issues off of this bike and it is the most comfortable I have ridden to date.
2013 CROSS COUNTRY TOUR
cpeny is offline
post #5 of 15 (permalink) Old 01-05-2014, 02:49 PM
MTVic's Avatar
Never heard of a passenger being uncomfortable unless you are referring to A HD Ultra Classic. The heat is mostly noticeable to the driver's left leg, but certainly not hot in comparison to other bikes with similar wind protection.
yes it is hotter than the same bike or others with no lowers. My friend has a 2013 HD anniversary Edition and his wife complained constantly about her feet burning. He rode mine and said heat was less for her and him. On his, he had to pull the catalytic converters to cut the heat, which some do also on the XCT, but you may loose HP.
Mike
FORMERLY 2012 Black XC Tour
2016 Honda NM4
2014 Honda CTX 700 dct
MTVic is offline
post #6 of 15 (permalink) Old 01-05-2014, 09:52 PM
When we lived in S/W Florida my wife rode her Vision four years. Her right leg would get medium rare from the heat. I wrapped the rear pipe, helped some, installed Baker air wings, helped some but it was still hot.
She is now on a XC, although up here in N/E Georgia some extra heat would be a good thing about now. The Vision was a fantastic bike, handled like a dream.
2008 Vision Black gone 2005 TC- Sold
1963 Triumph Bonneville,not sure on color-be awhile
1983 XS 650 Custom Midnight Gold
2007 Ural Patrol Black-Sold
2011 Cross Country White and Silver
2012 Cross Country Red and Silver--Hers
A bunch of other bikes over the years, mostly all good
Life is short, eat dessert first, simple enough.
N/E Georgia and my garage
Shuffles is offline
post #7 of 15 (permalink) Old 01-05-2014, 10:32 PM
slickvic's Avatar
You will have to tune it to knock the heat down. 20* drop in temp on my bike after tune. It's expensive but all air cooled bikes need help. The EPA tuned our bike's at the factory. Lean !
slickvic is offline
post #8 of 15 (permalink) Old 01-05-2014, 11:30 PM
I agree.
All EPA tuned bikes run a bit hot.
My 2005 Road King lost 20 or 30 degrees of head temp heat by porting the heads and a quality tune (thundermax) .
I will be doing a PCVw/autotune soon. Then a Bassani Header w/o a cat.
Right now; I think much of the heat from the engine is soaked up by the frame right behind engine. Some of that heat is deposited into the seat.
orbiker is offline
post #9 of 15 (permalink) Old 01-08-2014, 04:39 PM
What is this heat you speak of? Never had an issue on my Hardball.
2012 Hard Ball
Frankyoz is offline
post #10 of 15 (permalink) Old 01-09-2014, 07:08 AM
A fuel controller or even a S1 flash along with a free flowing exhaust will do wonders towards engine heat output. Maybe why your Vision wasn't hot if it was set up good that way. I removed the right side cat on my XC, bent over the diverter plate in the crossover so the exhaust mostly comes out the right side and now I almost wish I had more heat coming off the engine on cooler days.
40XC is offline
