Engine Noise - Victory Forums - Victory Motorcycle Forum
post #1 of 30 (permalink) Old 07-03-2011, 08:27 AM Thread Starter
Default Engine Noise
Greetings to all, I just purchased a 2011 Cross Country and just love the bike but have one question. After riding the bike for awhile if you stop and shift into neutral and let out the clutch the engine has a knocking sound or rattle in the engine, Pull the clutch in and it stops. Is this normal?
Thanks
nwkshusker is offline
post #2 of 30 (permalink) Old 07-03-2011, 09:59 AM
ammo_umb's Avatar
If the noise is the same with the clutch pulled in while in gear as it is while you are in neutral it is normal. There's a lot of weight getting slung around in your engine that increases with the transmission engaged; you are going to hear noises. Gear noise is something you will never get away from -- it's almost better to get used to paying attention to the engine noise which sounds much more like a sewing machine.
People that have never rode a bike with a windshield or that have only rode bikes with minimal windshields are the most sensitive to the noises. Those people are usually the first in line to upgrade their exhaust. Which is fine; it keeps the exhaust companies in business.
If you are one of those people look for the D&D group buy post from CrossRoads; he is working to try to get a reduced price -- if enough people elect to join in the purchase the price reduction could be significant.
Retired USAF, IYAAYAS!
ammo_umb is offline
post #3 of 30 (permalink) Old 07-03-2011, 03:04 PM
The Diamond
diamondrmp's Avatar
Welcome to the Victory Forums.
A few helpful pointers,
  • Please take the time to read the “Sticky” threads in the “Victory Forums Rules and New Members Introductions” forum. This will help you out a LOT with the Victory Forums.
  • The Search feature is your friend! You will find the answers to a lot of your questions by using it.
  • If you are asking questions that are of a technical/mechanical/electrical/performance nature, please place them in the “Victory Tech and Performance” forum. This will speed up a response. Placing them in the model specific forum can delay a response.
Please add the year and model of your bike to your signature, so we know how to help when you ask a question!
diamondrmp is offline
post #4 of 30 (permalink) Old 07-03-2011, 03:21 PM
Archer's Avatar
Thanks
I am a new XC owner also. I have noticed the exact same issue that you described. I first noticed it as soon as I got home from picking up the bike. I was so concerned that I immediately called the dealer back. They didn't seem to know what I was talking about but said I should bring it back in. Problem is they are 60 miles away. I have still not gone back in but I have read on here that the noise we are hearing seems to be the throwout bearing in the clutch. I also read that this can be adjusted via the clutch cable at the engine. One thing I have noticed is that my bike doesn't always make the noise while in neutral. I don't understand that. I've decided that when I have the 500 mile service done I will address it then. I'm taking a little comfort in the fact that it seems to be very common. There are a couple of threads on it. One even has a video that sounds very much like mine. I wouldn't worry too much imo.
Chris
2011 White/silver XC
Arlen Ness Big Honkers
PC V with custom dyno-tune by Kevinx (110 hp 114 tq)
VictoryHID.com ugrade
Lloyds VM1-DR cams
Lloydz timing wheel (+6)
Lloydz Perfomance filter
1/4 turn throttle ring
Rockford Fosgate amp
jtdcycleparts hard lowers
Archer is offline
post #5 of 30 (permalink) Old 07-03-2011, 06:19 PM
EDHARRISON's Avatar
Air / oil cooled V twins are noisy, no water jackets to dull the noise, clutch noise when pulled in is also noisy. If its really bad take it to your dealer but most is normal...
Victory Vegas 8 Ball 2009 (5 speed 100ci)
Stage 1 with Swept black exhaust / Ness bars / Lowered
EDHARRISON is offline
post #6 of 30 (permalink) Old 07-03-2011, 09:15 PM
Bad V V's Avatar
Do a search you'll find many threads that will answer your question.
2003 Victory vegas
Bad V V is offline
post #7 of 30 (permalink) Old 07-04-2011, 06:35 AM Thread Starter
Thanks for the answers, I appreciate it.
post #8 of 30 (permalink) Old 07-07-2011, 06:00 PM
Normal noise. When I bought my first Vic King Pin in 07 I had the same reaction. I called the dealer and complained. They said it was normal sounds. I now have a 2011 XC and same sounds. Gear driven primary makes lots of clatter noise but these engines are very strong. I just tell people it's the brass balls the bike has. Louder pipes help but just ride and enjoy you will get used to it.
Ranman:cool:
2011 XC (Black)
2007 KP Tour (Graphite & Pearl) Traded
Suzuki GT750 (Water Buffalo) Purple/White
1973 Kawasaki 90 street (1st bike)Kawasaki Green
Ranman is offline
post #9 of 30 (permalink) Old 07-07-2011, 07:11 PM
Archer's Avatar
Just out of curiosity can anyone tell me why my bike doesn't always make the sound? This a.m. I started it up and no sound. Got to work...no sound. However when I got home this afternoon it was back. It didn't matter if I pulled in the clutch it not. It was still there. Now if I put it in gear it goes away every time. Thanks.
Chris
Lloyds VM1-DR cams
Archer is offline
post #10 of 30 (permalink) Old 07-07-2011, 07:44 PM
Temperature of the day is one possible cause. The hotter it is the louder mine is. The only noise I haven't gotten used to is the sound like a loose tappet. Obviously this bike has no tappets as it's hydraulic lifters but that's the sound. Everything else I don' mind. It took awhile to get used to my last bike as well, it was very noisy, then one day I just didn't notice it anymore.
WilCon76 is offline
