Heavy popping after de baffling - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 01-09-2014, 11:47 AM Thread Starter
Dustin0479's Avatar
Default Heavy popping after de baffling
I removed my baffles a couple weeks ago, sounded a bit better but not great so i cut the 1.25" tips off and installed some 2.25" tips.
She pops pretty bad when decelerating now, any problems with allowing this until I get a tuner and dyno later this year?
Dustin0479 is offline
post #2 of 10 (permalink) Old 01-09-2014, 11:55 AM
try speed shifting, other wards don't close the throttle all the way when you shift. That should cut down on the popping
post #3 of 10 (permalink) Old 01-09-2014, 12:43 PM
CrossRoads's Avatar
If you're still using the stock air filter, you're fine to wait as is without doing any damage. Disconnect your OČ sensors if you haven't already, and that will help.
CrossRoads is offline
post #4 of 10 (permalink) Old 01-09-2014, 01:57 PM
Pop
Massage the connections.
Popping can be the result of outside air getting in during decel and touching off the unspent fuel. If muscling the clamps doesn't improve it, there's exhaust butter you can lather into the connections to fill gaps.
Might not work, but it might and it's cheap.
It's not entirely out of the question that during the debaffling you could have tweaked the exhaust gaskets and they might warrant replacement. Not likely though unless you did the job with a three pound hammer.
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
post #5 of 10 (permalink) Old 01-09-2014, 03:04 PM
luvmyride's Avatar
That is where I would start. Just remember to give it a few miles for the ECU to compensate for the sensors being disconected. May take 50 or so miles.
It won't hurt anything (but your ego).
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #6 of 10 (permalink) Old 01-11-2014, 11:45 AM
BenD's Avatar
If, after trying the suggested methods, you still have popping, buy and install the Lloydz IAV. This was THE final solution for my popping, after buying a PC-V(suggested by AZ VICTORY), dyno tuning, and Lloydz air filter.
2012 XC Tour, Sunset Red/Silver PC-5 Thrush mod pipes Lloydz air filter and timing wheel.
California Sidecar Trike Conversion
Phoenix, AZ
BenD is offline
post #7 of 10 (permalink) Old 01-12-2014, 03:52 AM
TNXR's Avatar
When I put on my WD baffled pipes last year, my XR popped like crazy for the first 100 miles or so but started to slowly go away. They say the computers in these things are not very high tech but it seems have done something to cause the popping to lessen. I now only get pops every now and then, mainly when shifting gears at to low of a RPM.
2011 Cross Roads Sunset Red
TNXR is offline
post #8 of 10 (permalink) Old 01-12-2014, 10:05 AM
dtmmil's Avatar
If your 02s are already disconnected, reconnect and try. The only time i had any real popping with mine was when mine were disconnected with no tuner. Popping on decel can be both rich or lean, depending on the pop, one big bang is usually rich, jake brake sound is generally lean.
Sent from Motorcycle.com App
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #9 of 10 (permalink) Old 01-12-2014, 11:54 AM
Would be nice if you say what year and model. Never ask with out telling all
post #10 of 10 (permalink) Old 01-12-2014, 11:59 AM
dtmmil's Avatar
I think its a 12-13xc he had another post about his pipe mod.
currently bikeless
Hawley MN(sold)
dtmmil is offline
