Auto Volume Control with an Amp - Victory Forums - Victory Motorcycle Forum
View Poll Results: What option do you use with your AVC (Auto Volume Control)?
Off 4 33.33%
AVC On LOW - Rockford Fosgate Amp 3 25.00%
AVC On MEDIUM - Rockford Fosgate Amp 1 8.33%
AVC On HIGH - Rockford Fosgate Amp 2 16.67%
AVC On LOW - Other Amplifier 2 16.67%
AVC On MEDIUM - Other Amplifier 0 0%
AVC On HIGH - Other Amplifier 0 0%
Voters: 12. You may not vote on this poll
post #1 of 8 (permalink) Old 01-21-2014, 01:37 PM Thread Starter
arkiebiker's Avatar
Default Auto Volume Control with an Amp
I know some of you said you do not use Auto Control with your AMPS, however some of you say you do...
Thought I'd do a poll and just see what we're all doing.
If you want to "justify" your position...all the better.
Wally
Searcy, AR
Blytheville, AR (Hometown and the BEST BBQ Sandwiches in the world)
Arkansas Bikers Website
http://www.arkansasbiker.net
Garmin Zumo GPS Forums
http://www.zumoforums.com
arkiebiker is offline
post #2 of 8 (permalink) Old 01-21-2014, 01:42 PM
I voted low, but normally its off. I tried medium and high once, and won't be doing that anymore, I feel its too much. Its pretty easy to spread the left thumb out to pump the volume rocker up/down.
Doc.
Doc, SHO RYDERS MC Road Captain.
2013 Sunset Red Cross Country. 10" 7JuRock Windshield, black framed Victory passenger backrest, Vicotry backrest, tinted tail light and rear blinkers, Thrush mod,polycarbonate fork lowers and vinyl highway bar soft lower covers, PBR300-2 Amp, Lloydz PTS & Air Filter.
SR-DOC is offline
post #3 of 8 (permalink) Old 01-21-2014, 02:22 PM
jwolfpack02's Avatar
I keep it off...was terribly distorted when I used it, no matter the setting.
21" front wheel, lowered 1.5"
jwolfpack02 is offline
post #4 of 8 (permalink) Old 01-21-2014, 06:08 PM Thread Starter
arkiebiker's Avatar
That's why I did this poll...I think it's crazy that so many of us get so many different sounds...and yeah, I know it may depend on radio, iPod or XM radio...but still kinda crazy.
Searcy, AR
post #5 of 8 (permalink) Old 01-21-2014, 07:32 PM
luvmyride's Avatar
I use the AVC on low with my RF amp. I don't experience any distortion with my iPhone streaming Pandora Radio (90% of the time, my choice of audio).
I like not having to turn it down so much when I come to lights. Only 2-3 notches with it on compared to 6-8 with it off.
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #6 of 8 (permalink) Old 01-22-2014, 01:09 AM
tonygiotta's Avatar
I don't use an RF amplifier (have a Hawg Wired) but I did quite a bit of experimentation with it. So far as I can tell, all the Auto Volume Control does is automatically control the volume for you.
I know, sounds stupid, right? But basically it just turns the volume up for you at speed. I made my gain adjustments with my master volume set at 23 (~75%) with the auto volume off and the sound settings flat as per the directions provided by HW. I used their Remote Link unit so I was able to see by way of an LED indicator exactly when the amp started clipping due to the gain being set too high.
When riding with the Auto Volume off, the indicator would begin to flicker when I turned it up to 24. When riding with the Auto Volume set to low, the indicator would begin to flicker at 16 if I was riding at a high rate of speed. Switching between low and off at a constant speed of about 60mph also revealed that 16 on "low" sounded just as loud and clear as 24 on "off". It seems to me the Auto Volume on low just gradually turns up your volume about 8 notches or so as you get up to speed. I would venture a guess that those who hear distortion with the Auto Volume active are hearing distortion due to the voulme being set too high while the bike is at a stop.
So my vote... AVC set to low, with an "other" amp, with the volume set about 8 notches lower than it would be otherwise. I like the convenience of not having to turn down the stereo at red lights as I don't feel the need to make others listen to my music at a volume that caused my ears to ring for about a day after dialing in my settings!
'04 Kingpin - Blue w/ Tribal Flames (sold)
'12 Cross Country - Imperial Blue
tonygiotta is offline
post #7 of 8 (permalink) Old 01-22-2014, 08:05 AM Thread Starter
arkiebiker's Avatar
I think I figured out why I was so disappointed with the volume settings with the Rockford Fosgate Amp...
The RF Amp replaced my Biketronics DIGITAL AMP. That amp is a 300 watt amp and 100 watts RMS...the RF Amp is 300 watts, but only 75 watts RMS. I don't know if this makes a difference or not, but I assume it does.
Anyway, I'll be putting my Biketronics Amp and the Biketronics Speakers up for sale soon...just wanna do a couple of rides with this setup before I sell (In case I want to go back to the Biketronics).
Searcy, AR
post #8 of 8 (permalink) Old 01-22-2014, 12:26 PM
toejam's Avatar
Probably because you have the gain set too high (just a guess)
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is online now
