Oil Change Kit - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 07-22-2011, 07:07 PM Thread Starter
Question Oil Change Kit
Please forgive me if someone already covered this, but what are the two O rings for and the two different size washers for in the Victory oil change kit? I know one of the new washers goes on your plug before you reinstall it, but what is the rest of the stuff for? Sorry about the dumb question but I would rather ask then assume...
BikinVikin is offline
post #2 of 6 (permalink) Old 07-22-2011, 10:00 PM
ridinman's Avatar
The oil change kit has parts for multiple bikes.
Some bikes use 6 quarts of oil, some use 4.5.
Check your manual for the correct info on what you're supposed to use.
Ride Safe, Ride Often
Life's to short to be GRUMPY
Bill
2014 XCT
Lenexa, KS
ridinman is offline
post #3 of 6 (permalink) Old 07-23-2011, 01:25 AM
You don't actually need to change the copper washers every time. A lot of folks go many oil changes before changing a single washer. Best thing to do is reuse the washer and if it leaks; change it. It's very simple thing to pull the plug, put your finger over the hole, change the washer, and re-insert the plug. Do this when the bike's cold though. It's not a bad idea to get one of the magnetic oil plugs somewhere along the way too. Witchdoctors is a good source. Same with Noemtz.
post #4 of 6 (permalink) Old 07-23-2011, 07:06 AM Thread Starter
Thanks, appreciate the info. Which bikes' use the larger washer and O rings?
2011 Cross Country
post #5 of 6 (permalink) Old 07-23-2011, 04:04 PM
Witch bike use 6 quarts
Make sure you check the oil with the bike straight up and down. If you need to put it on a 2x4
post #6 of 6 (permalink) Old 07-24-2011, 07:08 AM Thread Starter
Thank you. I will check out the magnetic oil plug.
2011 Cross Country
