Broken Radio Antenna - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 07-24-2011, 12:31 AM Thread Starter
Default Broken Radio Antenna
I broke the radio antenna today while placing a cover on the bike. I merely pushed the antenna forward and hooked it under the driver's backrest. The antenna mast did not flex and broke at the half way point. I now understand one should not attempt to bend the antenna.
The bike is a month old, with less than 1K miles. I always cover my bike while at work. I have done it with my Wing for the last few years with no issue. The XC antenna is very brittle, and I am afraid that it will brake again if I replace it with the OEM antenna. Any suggestion on a superior after market antenna that will fit the existing mount?
Your assistance is appreciated.
JC
JC0808 is offline
post #2 of 7 (permalink) Old 07-24-2011, 06:52 AM
RonBou's Avatar
Look down.... There's options just below your post.
Ron
2012 Victory Cross Country Tour (Stage 1)
2011 Victory Cross Country (traded in on XCT)
2009 Triumph Rocket III Touring (traded in on XC)
1998 Valkyrie Tourer (Hydralocked - sold as is)
1966 Honda 305 Dream (for sale)
1967 Honda 305 Scrambler (project)
1982 Honda CB900 Custom (need to put back together)
RonBou is offline
post #3 of 7 (permalink) Old 07-24-2011, 07:01 AM
JC
There is a thread called "Short Antenna for X/C" on page 8 of this forum that might help you out. But you will have to do a very minor modification to get the mast to fit the Stock mount. The modification should give you several choices of After Market Antennas at several Auto Stores
2011 Cross Country
Lloydz HOH-VM1-DR Cams
Arlen Ness Big-Shot 2 P/N 18-627
Performance Air Filter
D&D exhaust
Gustafsson +4 Shield
I POD
Adjustable lowering Link
Kicker PS52504 Speakers
Titan Amp BT454
08 VTX1800F sold
06 1200R Sportster sold
1979 Yam 750 Special sold
simpletruth is offline
post #4 of 7 (permalink) Old 07-24-2011, 03:44 PM
auto store some carry a short plastic one that bends and pull in station very well
post #5 of 7 (permalink) Old 11-20-2013, 08:13 PM
I lost the antenna on mine sometime over the last couple of weeks. I went to Advance Auto and got one of thier universal replacement antennas. I went cheap and got a 13" rubber coated, flexible antenna for $8. It comes with various screw adapters and I found the one that worked. I trimmed about an inch off of the plastic base cover that came with the replacement antenna just to make it look good.
The results are great and signal reception is only a little worse than the original antenna. More importantly, the antenna does not stick out much from the back and won't interfere with a cover. Advance Auto did have a longer antenna for about $14 that would probably get better reception.
2012 XCT
Fi2000PowerPro
K&N Filter1999
H-D Dyna Convertible
prhukka is offline
post #6 of 7 (permalink) Old 11-21-2013, 07:49 AM
MNBill's Avatar
I got an antenna at the local HD shop (look for the clothing store that has a few bikes and you will know you are at the right place ). It has a spring on the bottom and flexes well. I had to cut the head off a metric bolt to make a threaded rod and thread it on. My radio reception improved dramatically.
IPOD wiring, Cee Bailey lowers, Klock Works windshield, Corbin seat
Previous rides:
2003 Valkyrie Standard
2004 1300 VTX
1997 Honda ACE 1100
MNBill is offline
post #7 of 7 (permalink) Old 11-21-2013, 07:59 AM
file or sand down the tip of the antenae still on the bike. pull the rubber tip off the broken piece and glue/silicon it on the filed down "shortened" antenae on the bike. check your reception. if it works to your satisfaction, cost nothing.
i cut my original down to about 11". works fine for me.
2010 xc
alphawlf99 is offline
