Rotating clutch/brake levers - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 01-28-2014, 12:32 PM Thread Starter
Send a message via AIM to ALRRider
Default Rotating clutch/brake levers
Is it possible to rotate the clutch/brake levers on the handlebars so that they are more horizontal? I feel like I have to reach down from the grips to get to them.
ALRRider is offline
post #2 of 3 (permalink) Old 01-28-2014, 04:22 PM
Encmerk's Avatar
You certainly can, just loosen the Allen screws that hold the brake and clutch clip in place and rotate. On the clutch side be careful about location with respect to mode switch for trip computer. I would have not noticed it but read in a forum last night from another member. If you cannot rotate, then you need to clip off the alignment tab from the back where it goes into alignment hole on handlebars. It is for the factory to ease in installation and uniformity.
Master Sergeant, USMC Retired
2002 HD Sportster 1200 Custom -sold
2013 XCT Boardwalk Blue picked up 1/21/2014
Vance and Hines hi output slip-ons
Lloydz hi-flow air filter
PCV w/AT
Lloydz ATS @ +4
CrossRoads HID's Hi and Low
Havelock, NC
Encmerk is offline
post #3 of 3 (permalink) Old 01-28-2014, 08:11 PM
slickvic's Avatar
I drilled another hole into my HMD bars to relocate for my reach. I didn't want things to loosen up on the bars. The alignment hole does help to keep the controls locked in place.
slickvic is offline
