Harley Edge Cut Hwy/Shift/Brake Pegs - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 07-31-2011, 09:15 PM Thread Starter
Default Harley Edge Cut Hwy/Shift/Brake Pegs
I am considering these Harley shift/hwy pegs with the kewlmetal hwy bracket and kuryakyn peg mount for my XC. Anyone currently using this set up? If so, will the pegs fit the Kuryakyn mount? Also, are the stock shift/brake pegs a similar screw-in arrangement (size) of the Harley shift peg, or will some modification be necessary?
http://accessories.harley-davidson.c...e-cut-footpegs
http://www.kewlmetalstore.com/produc...roducts_id=437
http://www.kewlmetalstore.com/produc...roducts_id=232
Cabo is offline
post #2 of 4 (permalink) Old 08-01-2011, 11:49 AM
The threads Harley and Victory use to attach the shift and brake pegs are different. I can't recall what they are but H-D's are SAE and Vic's are metric.
post #3 of 4 (permalink) Old 08-01-2011, 06:54 PM Thread Starter
RICZ: thanks. Kind of thought that might be the case. I'm primarily interested in the hwy peg set up at this time. It would be nice to have the shift/brake pegs match the hwy pegs, but I can live with stock shift/brake.
Cabo is offline
post #4 of 4 (permalink) Old 08-01-2011, 09:25 PM
Arlen Ness sells adapter for the shifter or JP cycle sells it too
You unscrew the screw thats in the peg and then screw it the adapter and your set to go.
