How Do You Remove Pipes from Engine?? - Victory Forums - Victory Motorcycle Forum
post #1 of 25 (permalink) Old 02-05-2014, 10:00 PM Thread Starter
Default How Do You Remove Pipes from Engine??
I have a pair of Lloydz exhaust gaskets on the way and in preparation to install them, I started to remove the front pipe. Got the joint clamp loose as well as removing the stud nuts at the head. The oval plate is loose and pulled off the studs. Sprayed some penetrate on both the joint and where the pipe enters the head and yanked and yanked and yanked. No movement. HELP!
post #2 of 25 (permalink) Old 02-06-2014, 10:52 AM
depot picker's Avatar
After yanking them every way possible to the point of exhaustion, I realized it wasn't that loud after all.
depot picker is offline
post #3 of 25 (permalink) Old 02-06-2014, 11:04 AM Thread Starter
Er, thanks...I think. Fortunately, I came across this video to aid me with this project. Together with your help, I should be able to have this project done by riding season 2017.
http://biggeekdad.com/2010/11/turbo-encabulator/
post #4 of 25 (permalink) Old 02-06-2014, 12:42 PM
RedIsland's Avatar
I think Witchdoctor has a video for this.
In with the new :2013 Suede Nuclear Sunset XC
Out with the old : 2011 Suzuki Boulevard M50
WARNING: I cannot be held responsible for the things I say or do until my blood alcohol level is 0.00% and caffeine has reached my blood stream.
RedIsland is offline
post #5 of 25 (permalink) Old 02-06-2014, 12:50 PM Thread Starter
The video they have describes what it takes to replace an entire exhaust system, not just the gaskets unfortunately.
post #6 of 25 (permalink) Old 02-06-2014, 01:08 PM
After watching that I'll go try again.
post #7 of 25 (permalink) Old 02-06-2014, 01:18 PM
LILMAGS500's Avatar
Ric , you are too funny ... Just keep removing nuts and bolts until pipes come free , in fact looks like you have to loosen and dismantle most of the system .... I would take depots advice and put it all back together , probably isn't leaking anyway . Although , now that your crush gaskets are already crushed .... It will leak ! Sorry Buddy
LILMAGS500 is offline
post #8 of 25 (permalink) Old 02-06-2014, 01:22 PM
vindex1963's Avatar
BFH perhaps
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #9 of 25 (permalink) Old 02-06-2014, 01:37 PM Thread Starter
Its our turn to get snow. Can't ride, might as well wrench. Keeps me out of the pool hall.
post #10 of 25 (permalink) Old 02-06-2014, 03:15 PM
irv
irv's Avatar
youre supposed to have EXHAUSTion working on pipes
and mufflers.
best i got today.
mph faster].
irv is offline
