Brake and shifter pegs - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 02-06-2014, 06:37 PM Thread Starter
New Member
Default Brake and shifter pegs
Wanting to change out brake pedal and shifter peg from '12 XC. Vice grip is only turning the pedal. Can't see if there's a screw to undo. Need insight....
artiestagg is offline
post #2 of 5 (permalink) Old 02-06-2014, 08:46 PM
I changed both of mine with a pair of vice grips. They both screw out, you just have to get a good "bite" with them. Good luck and let me know how it turns out.
Blade15 is offline
post #3 of 5 (permalink) Old 02-06-2014, 10:23 PM
jwolfpack02's Avatar
heat them up a bit if you haven't already. They have loctite on them from the factory and can be a bear if they're cold.
21" front wheel, lowered 1.5"
jwolfpack02 is offline
post #4 of 5 (permalink) Old 02-07-2014, 09:31 AM
vicray's Avatar
Location: In a place called Misery (Missouri) per my neice
Like jwolfpac02 said - a little heat and place the vise grip next to the brake lever and turn counterclockwise - It will come loose......
Remember to clean the used loctite out of the threads and put new loctite on the new pedal threads.
Keep us posted.
"When I ride, it's miles of Smiles" :)
__________________________
2013 Victory Cross Country Tour
2003 VTX 1800C Sold- Aug 2013
Formerly from Sterling Hts., MI
Now residing in Wentzville, MO
Hope to move to Florida in the near future
vicray is offline
post #5 of 5 (permalink) Old 02-07-2014, 12:45 PM
clamp the vice grip down tighter and turn counter clock wise
