21 or 23" front wheel? - Victory Forums - Victory Motorcycle Forum
LinkBack Thread Tools
Old 02-07-2014, 08:49 PM Thread Starter
New Member
Default 21 or 23" front wheel?
Hey guys I'm having trouble deciding on installing a 21 or 23" front wheel on my new XC? Is there that much of a difference in appearance? If anyone has photos or any feedback it would be appreciated. I'm going on Friday to order one.
wpike101 is offline
Old 02-07-2014, 11:57 PM
grh450's Avatar
Racking my brain as well!
And THEN there are so many different styles
1983 Yamaha YZ 490
2011 KTM 350 SX
2015 X1
2015 MAGNUM-TRADED
2013 Cross Country-TRADED
2008 Kingpin-TRADED
2005 Vegas Anniversary-TRADED
Gold Canyon, AZ
grh450 is offline
Old 02-08-2014, 03:47 AM
Encmerk's Avatar
Please take a look at this thread https://www.victoryforums.com/showthread.php?t=65018 Dustin0479 has installed a 23" and has good pics. He would be a great person to ask about why he went there instead of 21". Good luck with whichever you choose.
Master Sergeant, USMC Retired
2002 HD Sportster 1200 Custom -sold
2013 XCT Boardwalk Blue picked up 1/21/2014
Vance and Hines hi output slip-ons
Lloydz hi-flow air filter
PCV w/AT
Lloydz ATS @ +4
CrossRoads HID's Hi and Low
Havelock, NC
Encmerk is offline
Old 02-08-2014, 03:50 AM
DirtyDan's Avatar
Do the 23".
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
Old 02-08-2014, 07:54 AM
Reams's Avatar
I went with the 23. I like the look of a little extra rake. The only con I can find with the 23 is that your bike will lean more on the stand. The 23 with the 6 degree trees will put your bike 1 inch higher in the front than stock, so it does make it heavier to get off the stand.
A 21 with the trees would be back at stock height. HMD is making a new tree for the 23 that rakes it a little more and is supposed to keep the bike at stock height and eliminate the need for the travel limiters in the forks, but you do have to lower the rear end.
Either way you go be prepared to spend way more that you budget, because it will mushroom. Cost of Vic paint, labor(unless you can wrench), special Vic only tool to torque the stem, matching rotors, etc…...
Almost forgot, if you go with a 23 you only have two options for tires - Avon or Vee Rubber. Have heard that others are supposed to start making the larger sizes, but when I did it those were the only two available.
2011 Cross Country
Reams is offline
Old 02-08-2014, 11:16 AM
so if you raise the front end by 3" or 5" will you be able to adjust your headlight down enough. What about kick stand.
visionjohnny is online now
Old 02-08-2014, 01:38 PM
Reams's Avatar
I could not get it to the exact spec called for with the 23 and raked trees. Got real close - about 1 inch or so off of what is called for in the manual. The new HMD trees are supposed to correct that by changing the angle of the fairing back to stock.
2011 Cross Country
Reams is offline
Old 02-08-2014, 02:47 PM
BBob is online now
Old 02-08-2014, 05:21 PM
Reams's Avatar
I thought HMD had some kickstands to accommodate the difference...
He only has kickstands for lowering the bike. The way the stand tucks up next to the engine there is no room to lengthen it.
2011 Cross Country
Reams is offline
Thread Tools
