RPGS 300x4 connection issue - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 02-13-2014, 01:01 PM Thread Starter
Jckercheval's Avatar
Default RPGS 300x4 connection issue
Does anyone know why hooking up the Rockford Fosgate PBR 300 x 4 amp would cause the clock to just blink and not work? Ever since it was hooked up the clock just blinks and cannot be set. Amp works great...but it would be nice to know what time it is.
2013 Cross Country Tour & 2006 Vulcan 900 Classic,
Lloydz ATS Wheel
Lloydz Air Filter
Witchdoctor Voodoo HP Pipes
RF PBR300 with Polk MM531's
I love my wife....and motorcycles. She understands (most of the time)!
Coming to you from lovely Clear Spring, Maryland
Jckercheval is offline
post #2 of 5 (permalink) Old 02-13-2014, 03:31 PM
smoke's Avatar
Shot in the dark, did you run power and ground directly to the battery or grab power from a harness wire somewhere?
Smoke XC
2013 AntiFreeze Green
D&D exhaust, Gust. Smoke +2 Flip or 7" Dk Smoke shield, Kickers with Rockford Fosgate Amp, Vic Pass. Backrest & lots of extra chrome.
2011 Victory Blue XC - Traded
2007 Honda Blue VTX - Traded
smoke is offline
post #3 of 5 (permalink) Old 02-13-2014, 04:18 PM
toejam's Avatar
Also, did you hook up the constant wire? If so, disconnect it - its not recommended.
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #4 of 5 (permalink) Old 02-14-2014, 04:27 PM Thread Starter
I guess I should have said that I had it installed. It was a local shop that specializes in cars & motorcycles, but he said this was his first Victory. He doesn't know why the clock won't work. I'm trying to get some suggestions. He said he metered everything. If it warms up a little, I'm going to pull the fairing off tomorrow to see exactly how it's wired. Thanks for the suggestions.
Lloydz ATS Wheel
Lloydz Air Filter
post #5 of 5 (permalink) Old 02-14-2014, 07:04 PM
smoke's Avatar
My money is on one of those two.
Power and Ground NOT to battery
Turn on wire IS hooked up and positively should NOT be.
Smoke XC
smoke is offline
