Hazard lights.... - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 02-13-2014, 02:28 PM Thread Starter
Send a message via Yahoo to mrtappan Send a message via Skype™ to mrtappan
Default Hazard lights....
The Victory is only the second bike I ever owned with hazards (the other was a 04 BMW R1200). And today I got to use them.....
I put a air intake valve on my bike the other day. At four -ish turns out the bike idles at 1000-1050 RPMs. It also doesn't have enough spring pressure to keep it in that position. So while riding down the road, my bike stalls. It won't start and acts like it's flooded. I knew that little thing had something to do with it.
I pulled the cover off and it was at around six turns out or more. I tighten it back up and around three turns out it gets loose. So I tighten it to two and a half. Rode home around 800 RPM at idle.
Going to pull that spring off there and stretch that troublemaker. Or just find a replacement that works. Whatever. Either way, I'm getting my idle back.
Current toys:
2013 Victory Hardball - VM1DR cams, Lloydz filter, timing wheel, PCV-AT, 1/4 turn throttle, modified pipes
2008 Yamaha Warrior -Churchkey intake, V&H Bigshots
2007 Scion TC 5spd
1997 F150 -used to pull my car hauler
1989 Nissan Hardbody -absolutely indestructible
1968 Coupe Deville -all black, so nice
mrtappan is offline
post #2 of 5 (permalink) Old 02-13-2014, 03:17 PM
I had the same thing happen and I replaced the spring with a stronger one. I also informed Lloydz that they need to do the same.
So why did you bring up the hazard flashers, other than you used them? I use mine frequently, especially when I see traffic ahead has stopped or slowed.
post #3 of 5 (permalink) Old 02-13-2014, 03:43 PM Thread Starter
Cause the bike kept stalling on the Hwy 90 (coastal highway along the beach). Kept having to pull over and use them. Just fun to get some use out of them. I honestly never expected to turn them on ever.
Current toys:
2007 Scion TC 5spd
mrtappan is offline
post #4 of 5 (permalink) Old 02-13-2014, 06:28 PM
mrtappan, you might want to consider using them for the reason I stated so you don't get your rear end bashed in. I never trust those cagers behind me and neither should you or any rider.
post #5 of 5 (permalink) Old 02-13-2014, 08:29 PM Thread Starter
Well, true but I just thought it was funny because other than a Harley I used to own, I never owned a bike that "broke down roadside."
I just got a kick out of using the button. It was cute
I did kill a rear wheel bearing once in Montana. But that was negligence on my part. It had been going bad for awhile and I neglected it.
Current toys:
2007 Scion TC 5spd
mrtappan is offline
