Axle Thread; Left, Right, None? - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 02-13-2014, 10:49 PM Thread Starter
Default Axle Thread; Left, Right, None?
The service manual doesn't say, my dealer is ambivalent, so I'm asking you....
The front wheel axle of my 2010 XR has a hex recess in it on the right side. When removing it, do I turn the allen wrench clockwise, counter-clockwise, or are there no threads and I simply drift it out?
post #2 of 19 (permalink) Old 02-14-2014, 05:09 AM
lunaticrider's Avatar
Loosen the 2 pinch bolts and you will have to make or purchase a 14mm hex socket. It is easier to crack the axle loose with the bike on the ground with a zip tie around the front brake lever and grip (don't forget to remove zip tie before removing wheel). Threads are lefty loosey, righty tighty....
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #3 of 19 (permalink) Old 02-14-2014, 05:35 AM
wesdalton's Avatar
I think you mean 16mm (or a 5/8") will work. That is what I used on my 2010 XC
2010 X C
wesdalton is offline
post #4 of 19 (permalink) Old 02-14-2014, 05:39 AM
Tarzan's Avatar
Just curious, why do you zip tie the brake. I have never had to do that.I just undo the pinch bolts and loosen the Axle
'14 Ness XC
Tarzan is offline
post #5 of 19 (permalink) Old 02-14-2014, 05:45 AM
vindex1963's Avatar
Loosen the pinch bolts on the allen socket side, loosen the allen socket then loosen the other pinch bolts. I just did brakes and a tire.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #6 of 19 (permalink) Old 02-14-2014, 06:40 AM
You don't need to put the zip tie on (I don't) but if your doing it on the floor it keeps the bike from rolling around.
post #7 of 19 (permalink) Old 02-14-2014, 06:48 AM
Yes my bad, 16mm is the size or 5/8. I meant to type 16mm...
post #8 of 19 (permalink) Old 02-14-2014, 06:50 AM
You only need to loosen the one side of pinch bolts...
post #9 of 19 (permalink) Old 02-14-2014, 11:28 AM Thread Starter
Many thanks guys...I knew you'd come through. Preparing for the task, I made my own 5/8" "allen" wrench using a bolt with jamb nuts on the end opposite the head. Too cheap to buy one to use once every 4 years or so.
Baby's going to get new shoes...a set of Avon Cobras per the many comments I read on this forum. So, thanks again. You guys are great. Pat yourselves on the back for me.
BTW, for balancing, I'm going with Dyna-Beads this time. My tire man, who has many years experience with 'Wings and larger cruisers, sez the Ride-On (which I'm presently using) is OK if you don't do a lot of over 70mph riding, but the beads are good for all speeds. And I'll attest to that as I get an imbalance when doing over 70. I'll report on the results later.
post #10 of 19 (permalink) Old 02-14-2014, 11:44 AM
Put some anti seize on the axle treads and grease on the axle
You'll be glade you did when it comes to the next time
