Whiney engine. - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 02-17-2014, 03:38 PM Thread Starter
Default Whiney engine.
Picked up a used 2010 XCT 3 months ago and I like the bike except they high sounding whine noise that comes from the engine.
1) Can someone tell me what is causing this?
2) And can someone tell me if there's a way to mitigate or stop the noise (besides buying a new bike or replacing the engine)?
Thanks!!
Wyckedjester is offline
post #2 of 9 (permalink) Old 02-17-2014, 03:52 PM
You didn't tell us how many miles are on the bike. If less than 3,000 its still breaking in and will eventually get quieter. The primary case is full of gears and they are somewhat noisier than a chain, but nowhere near the hassle. I only hear the whine when idling and that doesn't bother me at all.
post #3 of 9 (permalink) Old 02-17-2014, 03:57 PM
Motorbikerx's Avatar
YES as RICZ says its the primary drive being gears,
stronger but noisier,
I like the whine myself, sounds tuff like a blower.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 9 (permalink) Old 02-17-2014, 04:00 PM
Lostintexas's Avatar
Thanks!!
Welcome to the mayhem.
Couple of things, cause I hate to see people taken. I hope there is a typo there because 12 was the first year of the XCT, maybe a XC dressed out. Kind of splitting hairs but cosmetics aren't the only difference, even though the rest are pretty minor and some done away with in a hurry.
Second, like rick said some whine a bit when new but not too bad. After getting off a Wing, I really didn't notice it much. I would say normal, but concern has been raised.
Cheers
I ride with the Force.
Lostintexas is offline
post #5 of 9 (permalink) Old 02-17-2014, 06:19 PM Thread Starter
Apologies, it's a Cross Country, not an XCT...
Cheers
post #6 of 9 (permalink) Old 02-17-2014, 07:00 PM
Send a message via Yahoo to mrtappan Send a message via Skype™ to mrtappan
I was quite shocked myself at how much extra noise the direct drive makes. I've have timing gears on cars before. I thought the bike would be quieter but it's basically just as loud.
Current toys:
2013 Victory Hardball - VM1DR cams, Lloydz filter, timing wheel, PCV-AT, 1/4 turn throttle, modified pipes
2008 Yamaha Warrior -Churchkey intake, V&H Bigshots
2007 Scion TC 5spd
1997 F150 -used to pull my car hauler
1989 Nissan Hardbody -absolutely indestructible
1968 Coupe Deville -all black, so nice
mrtappan is offline
post #7 of 9 (permalink) Old 02-17-2014, 10:05 PM
Rumrcity's Avatar
Its also possible the silencer was removed from the air filter. That noise is a little whiny, maybe whistley describes it better (I don't even know if that's a word). Either way, you get use to it.
2012 CCT- stage 1, Lloydz A/F, PCV, cams and dyno by Kyle, Lloydz ATS wheel,
sat radio w/ RAM mount
air horn(fairing), high beam HID,
RF amp w/polk db6501 frnt spkrs, Vic drvs backrest, 7Jurock 15" flip,
Pass handholds
Kuryakyn pegs
Cree LED lights on custom aluminum light bar.
Vic saddlebag covers, AirHawk R,
JEGS Heat Tape, AMSOIL 10W40
Rear Saber Lights
2012 Suzuki Vstrom
2006 Vulcan Nomad- sold
2003 Honda Spirit-sold
Long Island, NY
USMC 80-84
Rumrcity is offline
post #8 of 9 (permalink) Old 02-17-2014, 11:31 PM
nowhere near as loud as the straight cut timing gears on hot rods running around here, no way would I tolerate that sort of whine for long.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #9 of 9 (permalink) Old 02-18-2014, 12:53 AM
Krisd's Avatar
Thanks!!
Hell that's easy- it's all those ponies in there
2012 Hammer S
Freedom Performance pipes now wrapped, PCV, Loyds air filter, ATS, Loyds Cams and 1/4 Turn Throttle adj, Progressive rear shock
300mm rear and 23" front
Krisd is offline
