2013 Cross Country - power shut off in middle of riding - Victory Forums - Victory Motorcycle Forum
post #1 of 22 (permalink) Old 02-18-2014, 11:54 AM Thread Starter
Default 2013 Cross Country - power shut off in middle of riding
Hello,
I was wondering if anyone had experience with bikes head up displayarea turning off and on in the middle of a ride... Bike losses power and gear indicator goes out of wak. bike doesn't always stall out though.
The 1st time it happeneded I checked battery terminals and they were loose. It happened again over the weekend so I brought into Sky power in Lakeland to have diagnostic done.
They say nothing is showing an errors when running tests..
With that they suggested i have the bike dyno'd since i have pc5 and lloydz auto time system ...
Anyone have any thoughts???
Thanks,
JT
2013 Sunset Red XC
Arlen Ness Deep Cut Comfort Grips, Vicbaggers Contrast Cut Speaker Grills, Lowering Link, Vm1-dr Cams, PC5, LLoydz Timing Wheel, LLoydz Air Filter and True Duals Freedom Exhaust ( Dyno 116 / 117 )
previous bike
2009 Jackpot
Stage 1 with K&N filter and vented air box, Vic Swept with BCT baffles, PC 5 with tuner, Ness Flamed pegs and brake cover, Aligator seat skin and Tomahawk Sissy Bar
Lakeland, FLorida
JohnnyBravo is offline
post #2 of 22 (permalink) Old 02-18-2014, 05:21 PM
sthxc83's Avatar
Originally Posted by JackpotJT View Post
Hello,
Thanks,
JT
I would check your main breaker. I have read on the forum about a number of folks having them go bad.
Mike
2013 Nuclear Sunset XC - VicBagger Tarzan Bars, Gus +2 Euroflip, Goody Fork Lowers, Atom Bomb Exhaust, Lloydz Timing Wheel, Adjustable Lowering Link, VicBagger Tips, Kuryakyn ISO Grips, Ricz plate bracket.
Past Rides:
2004 Yamaha Roadstar Warrior
2003 Yamaha V-Star 650
sthxc83 is offline
post #3 of 22 (permalink) Old 02-18-2014, 05:53 PM
are you blipping the throttle killing the bike. Blipping is a no no
for sure get the dyno
post #4 of 22 (permalink) Old 02-18-2014, 06:57 PM
smoke's Avatar
I'm putting my money on the ol' battery terminals being loose.
You need to get in there and tighten them with a 10mm socket or wrench. NO screwdriver.
Smoke XC
2013 AntiFreeze Green
D&D exhaust, Gust. Smoke +2 Flip or 7" Dk Smoke shield, Kickers with Rockford Fosgate Amp, Vic Pass. Backrest & lots of extra chrome.
2011 Victory Blue XC - Traded
2007 Honda Blue VTX - Traded
smoke is offline
post #5 of 22 (permalink) Old 02-19-2014, 10:46 AM
tkirby16's Avatar
Default What's this?
What is Blipping????
Bulk
USN Submarine Veteran
2013 Victory Cross Country
PCV, Bassani Exhaust, HMD Gorilla Bagger Bars, Pass Floorboards, Pass Quick Disconnect Backrest, HID kit, Victory Derby/Cam covers, mirrors, Lloydz Timing Wheel and Lloydz Air Filter, Avon grips and Quarter Turn Throttle ring, RICZ laydown plate!!
Spring Hill, TN
tkirby16 is offline
post #6 of 22 (permalink) Old 02-19-2014, 10:51 AM
CrossRoads's Avatar
Jacking the throttle in short bursts to make the beast bark for no reason.
CrossRoads is offline
post #7 of 22 (permalink) Old 02-19-2014, 11:11 AM
tkirby16's Avatar
Default Blipping
So being not even a week old Victory owner, I take it that this blipping is a bad thing for Victory's?
Bulk
Spring Hill, TN
tkirby16 is offline
post #8 of 22 (permalink) Old 02-19-2014, 11:34 AM
And so are loose battery terminals. Helpful hint: Place lock washers under 'em and keep 'em tight.
post #9 of 22 (permalink) Old 02-19-2014, 11:39 AM
CrossRoads's Avatar
It's not bad, it just coughs and cuts off the fuel if it sees the RPM suddenly jump. It gets better as you break it in and if you add a fuel controller and timing wheel.
But also do make sure the battery connections are tight as the others mentioned. Lose battery connections are the most common reason.
post #10 of 22 (permalink) Old 02-19-2014, 11:43 AM
Motorbikerx's Avatar
yeah mine werent tight when I undid them to fit my Ness air filter,
gotta remember some lockwashers too.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
