XR Front Fender - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 08-14-2011, 09:04 AM Thread Starter
saddlebag's Avatar
Default XR Front Fender
Anyone know if a Kingpin front fender will fit a XR? It looks like there may be a clearance issue with the plastic oil cooler shroud.
saddlebag is offline
post #2 of 15 (permalink) Old 08-14-2011, 09:53 AM
The Diamond
diamondrmp's Avatar
I KNOW the XC fender is a direct bolt on for the Hammer and Kingpin so the KP will fit the XC but as far as the clearance goes I have no idea. Here is an alternative that will give you the clearance.
http://www.kewlmetalstore.com/produc...roducts_id=693
diamondrmp is offline
post #3 of 15 (permalink) Old 08-14-2011, 09:54 AM
ammo_umb's Avatar
XR has only been around a short time so it's doubtful anyone has tried it. Give it a shot and post pics!
Retired USAF, IYAAYAS!
ammo_umb is offline
post #4 of 15 (permalink) Old 08-14-2011, 09:59 AM
The Diamond
diamondrmp's Avatar
This is a pic of an XC fender on a Vegas that the owner threw Kingpin forks on. As you can see its a direct fit, so clearance will be your issue.
post #5 of 15 (permalink) Old 08-14-2011, 10:45 AM Thread Starter
saddlebag's Avatar
Thanks, but I like the longer look and think it would compliment the longer rear fender better than the trendy wedge hairdo look.
http://www.hairpedia.com/hair-styles...nt&pic_id=2235
post #6 of 15 (permalink) Old 08-14-2011, 10:46 AM Thread Starter
saddlebag's Avatar
I'll have to go take some measurements first. No money to burn in this economy...
post #7 of 15 (permalink) Old 08-14-2011, 11:24 AM
The Diamond
diamondrmp's Avatar
You misunderstood the link. It isn't for the fender but the rake kit. The rake will give you the clearance for a KP fender although you have to use a 21 or 23 inch wheel. If you decide to go with a 21 or 23 Ness sells a fender kit to clear the taller wheel.
post #8 of 15 (permalink) Old 08-14-2011, 11:29 AM Thread Starter
saddlebag's Avatar
Aha!
post #9 of 15 (permalink) Old 08-15-2011, 12:14 AM
Could always lower the back end an inch or two to go with the rake kit and use the stock wheel. Just a more affordable way to skin the same potato. I don't skin cats.
post #10 of 15 (permalink) Old 08-15-2011, 09:29 AM
The Diamond
diamondrmp's Avatar
I don't know much about "rake and Trail" in regard to bikes but I do know that the KM rake kit is designed to keep the trail correct but only with the 21 or 23 inch tire. I also know that the incorrect trail can cause tank slap at higher speeds.
Bbob does lowering the rear change the trail?
