LED licence plate frame wiring? - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 02-23-2014, 08:06 AM Thread Starter
Daybreak's Avatar
Default LED licence plate frame wiring?
Can someone tell me which wires would be the best choice for tapping into with the power lead from my plate frame? Is there a constant power wire inside the rear wiring harness under the seat?
Thanks for any tips!
2013 Cross Country Tour
-VM1 Cams, Lloyds ATS, Lloyds AC, VFC III, D & D Pipes, VictoryHID HI/Lo kit, 1/4 turn throttle ring, Highway Pegs, 7Jurock Flip Shield....
2009 Yamaha Raider 1900 Gone...but not forgotton!
Daybreak is offline
post #2 of 5 (permalink) Old 02-23-2014, 08:50 AM
Travis P's Avatar
Why not use the wiring for your existing license plate light?
Travis P is offline
post #3 of 5 (permalink) Old 02-23-2014, 08:57 AM
Mr_Buzzcut's Avatar
Thats what I did
2008 Hammer S
300mm Fat tire
USMC 87-92
Mr_Buzzcut is offline
post #4 of 5 (permalink) Old 02-23-2014, 09:00 AM
Encmerk's Avatar
+1 to the above posts. In addition, you don't want a 12v constant, it would stay on all the time. You want a 12v switched, which is exactly what the existing license plate light wiring is. Since you are going LED, current draw on existing wires should be fine, considering your lights for the plate are LED also.
Master Sergeant, USMC Retired
2002 HD Sportster 1200 Custom -sold
2013 XCT Boardwalk Blue picked up 1/21/2014
Vance and Hines hi output slip-ons
Lloydz hi-flow air filter
PCV w/AT
Lloydz ATS @ +4
CrossRoads HID's Hi and Low
Havelock, NC
Encmerk is offline
post #5 of 5 (permalink) Old 02-23-2014, 09:14 AM Thread Starter
Daybreak's Avatar
Appreciate it guys. Kinda what I figured, but wanted to make sure. The obvious choice isn't always the best one!
Thanks again.
Daybreak is offline
