power commander 5 and D&D pipes - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 08-16-2011, 08:36 PM Thread Starter
Default power commander 5 and D&D pipes
anyone have a map suggestion for a PC5 and D&D pipes on a 2011 XC?
rubiusbeer is offline
post #2 of 15 (permalink) Old 08-16-2011, 10:25 PM
I'm running the M19-006-003 map from the Vision on my XC...Bike runs great now, realy woke it up! I have D&D's, intake strip removed, performance air filter, and PCV with the AT.
cplabaunza is offline
post #3 of 15 (permalink) Old 08-16-2011, 11:29 PM
This is the second or maybe eighth time I've heard this tune works great for the XC's.
Sounds like a really good starting point to me! Maybe even the right tune for those doing the exact same mod's, eh!
post #4 of 15 (permalink) Old 08-17-2011, 07:16 AM Thread Starter
thanks guys for the replies. I'll post my results later in the week. thanks again
post #5 of 15 (permalink) Old 08-17-2011, 12:09 PM
Where do you get that map?
I used a FuelMoto map and I stall off-idle, pop between gears and my mpg dropped a lot. Now, I'm going to use the AutoTune to tweak it, but I'd like to start off with the map you mentioned.
2011 CrossRoads (D&D, PCV w/AT, Lloydz filter/cams)
2012 Can-Am Spyder
Twin Turbo Porsche 911
FFR 1965 Cobra 427
2011 BMW 135i convertible
1941 Chevy hotrod truck
petegtsv10 is offline
post #6 of 15 (permalink) Old 08-17-2011, 03:44 PM
toejam's Avatar
I take it the Power Commander V 19-009 will work on the '10 models? Or is there a different model, because I haven't found any listing for it, thanks.
(BTW - I'm going with nascar6's pipes)
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #7 of 15 (permalink) Old 08-18-2011, 05:15 PM Thread Starter
installed the pcv and the D&Ds today. they sound great. the 003 map is available on power commanders web site.
post #8 of 15 (permalink) Old 08-19-2011, 12:39 AM
Youcan get this map here: http://www.powercommander.com/powerc...PartNum=19-006
post #9 of 15 (permalink) Old 09-19-2013, 08:06 PM
tommyarmour's Avatar
Maps are right here:
http://www.powercommander.com/powerc...dl=364&yr=2013
2013 Metallic Flamed XC, D&D exhaust, Lloyds High Flow Filter, Lloyds Idle Air Valve, Lloyds Adjustable Timing gear, PC5, Auto-Tune. VM1 cams. JL Audio M400/4, Polk's MM651's and MM691's. Gorilla Bagger Bars, 6x9 saddlebag lids, 21" WitchDoctor Revolver wheel. Too many extra's to list!!!!
2006 Victory Hammer 106 Stroker kit, lloyds Torque Tubes, Bassani 2 into 1 exhaust, PC3. "Traded for 13' XC"
tommyarmour is offline
post #10 of 15 (permalink) Old 09-19-2013, 08:10 PM
TNXR's Avatar
Dang Tommy, you sure can revive some old threads!
2011 Cross Roads Sunset Red
TNXR is offline
