aw man, oil leak - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 12 (permalink) Old 02-24-2014, 08:39 PM Thread Starter
worm5932's Avatar
Default aw man, oil leak
so I had my bike running tonight to charge it up and let it get warm. well I noticed I have an oil leak, looks to be the cam/valve cover. anyone had to make this repair? I want cams and would like to go in once, but I cant float them now. I already have a trip planned for june, headed to the dragon, bout 1500-2000 mile trip. is something like what I have, something I can let go and just keep clean? or should I get right to it?
looks just like the picture 3/4 of the way around, ive never noticed it before tonight.
2010 cross roads, Lamborghini Monterey blue
victory fairing with my own audio kit
timing wheel, lloydz filter, atom bomb slip ons
PCV w/ auto tune, VM1 cams, dyno tune by the vic shop, 117HP 119TQ
worm5932 is offline
post #2 of 12 (permalink) Old 02-25-2014, 05:35 AM
TNXR's Avatar
I would probably get it fixed. If it is just leaking by the cam cover gasket (I assume there is one) then it shouldn't be hard to fix.
2011 Cross Roads Sunset Red
TNXR is offline
post #3 of 12 (permalink) Old 02-25-2014, 06:46 AM
Vicbuilder's Avatar
I have seen many bikes where the oil level was too high and it blew the excess into the air box. From the air box on a Vision or Cross bike it can leak past the throttle body seal and drip down on the motor.
So it looks like a bad oil leak, but in fact is a simple clean-up procedure. I've never had to fix a leaky valve cover (but it could of course happen) but I've had about 1-2 bikes a year with over full oil leaking down on the motor.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
post #4 of 12 (permalink) Old 02-25-2014, 07:14 AM Thread Starter
worm5932's Avatar
ill check that out, although I do the oil change every spring so it shouldn't be overfull. At least it was fine all last summer. I do start it at least once a month during the winter and let it get warm, might have some blowby adding to the level. would the motor need to be dropped to get that cover off?
worm5932 is offline
post #5 of 12 (permalink) Old 02-25-2014, 08:58 AM
Judge Redd's Avatar
I haven't checked your bike- but the specs for my Judge say 5 qts. While the manual
says change it with 4.5 qts max.
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #6 of 12 (permalink) Old 02-25-2014, 09:06 AM
Vicbuilder's Avatar
I'm not saying for certain that you don't have a legitimate oil leak, but here is what I see all the time.
Overfull on oil and starting to seep out the airbox seal:
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
post #7 of 12 (permalink) Old 02-25-2014, 10:07 AM
Lostintexas's Avatar
I have had this "leak' too. Look under the left cheese wedge and find the hose. Then make sure they are all connected, Do this after you check your oil. Oh BTW, mine was literally half a cup (4 oz) over filled. Didn't really show on the stick before or after, but that was what solved the problem.
Cheers
I ride with the Force.
Lostintexas is offline
post #8 of 12 (permalink) Old 02-25-2014, 10:20 AM
Luciferiad's Avatar
+1 on all this.
Judge Redd, that 5-qt capacity in your manual should only be for a dry motor. As in never been started.
Also, when I service I actually put in a couple ounces less than the 4.5-qt spec just to be safe. Picked up the habit on my Vulcan because they were notorious for belching oil into the air box if they were overfull the slightest
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #9 of 12 (permalink) Old 02-25-2014, 12:49 PM
Judge Redd's Avatar
Yep. This was back when I did my first change just before winter break.. I poured em in there, and there you go... Obviously a bit annoyed with the resulting overfill. So I pumped some back out, and it's good.
On a related note- some oil must stay somewhat trapped in the cooler. I noted that a tipping of the bike ( after initial draining) resulted in a larger than expected amount to come pouring out..
post #10 of 12 (permalink) Old 02-25-2014, 01:39 PM Thread Starter
worm5932's Avatar
thanks for all the replies, ill look into the oil level tonight if I get a chance. looked it over real good last night and don't remember seeing any oil higher than the seam of the cover.
another question, does anyone know if you get cams from Lloyds do they come with all the gaskets youll need?
gossfrank likes this.
worm5932 is offline
