Garage door opener.. - Victory Forums - Victory Motorcycle Forum
post #1 of 43 (permalink) Old 03-06-2014, 11:14 AM Thread Starter
Dustin0479's Avatar
Default Garage door opener..
Anyone wire one into your bike? If so, where did you wire to?
Sent from Motorcycle.com App
Dustin0479 is offline
post #2 of 43 (permalink) Old 03-06-2014, 11:22 AM
there is one you can wire into your headlight. You go high / low and door goes open.
http://www.ebay.com/itm/Flash2Pass-C...aa1944&vxp=mtr
sent from computer where I can search the net for answers
post #3 of 43 (permalink) Old 03-06-2014, 11:28 AM
CrossRoads's Avatar
Yes, Flash-2-Pass will do the job, however, it's not perfect and they try to hook you to using their openers, which are not cheap. On the XC/Vision bikes, I would just modify a current (preferably a broken) remote for your garage door. Give it power so it doesn't use the battery anymore, and add an accessory button on your dash.
CrossRoads is offline
post #4 of 43 (permalink) Old 03-06-2014, 12:38 PM
Lostintexas's Avatar
Range could be better, but my opener is in the back of the garage, FWIW. Not sure what CR is talking about but have priced openers and they are very competitive. I also put one on both cars, so it made the price even better. Jump the control box for the house into the existing one, or just replace it. The instructions are in the box and there are a few U-Tube type video's out as well.
I mounted mine under the fairing and wired it to the brights, grounded to an existing ground point. Did it all through the headlight opening so no need to remove the entire fairing unless you have some other projects going on under there.
Cheers
I ride with the Force.
Lostintexas is offline
post #5 of 43 (permalink) Old 03-06-2014, 01:02 PM
Flash 2 pass here too, very easy and other than my system not powering the included opener it was a 20 min job on my XCT. The next time I have a battery go out in another opener and I'm doing the same on my wife's car. No work on my end, just 2 connections and done.
2012 Victory Cross Country Tour, Sunset Red.
Parts added to make her louder, faster and more mine.
Stage 1 filter and pipes, Lloydz VFIII & ATW.
Clearwater Darla, LED GLO, emergency lights and siren.
Bushtec hitch and harness, Kompact Kamp trailer.
ChuglyXJ is offline
post #6 of 43 (permalink) Old 03-06-2014, 01:59 PM
kkent66's Avatar
I just purchased a 2013 XCT in December and had been riding a Yamaha RSV for several years. I put in a mo-door opener and loved it. Easy to use, easy to install, never had any issues with it. I took it out of my RSV and planning on putting in the front right storage area on my XCT.
http://www.mo-door.com/
2013 Cross Country Tour - Black - Columbus, Ohio
Hydraulic Clutch
Russell daylong saddle
Kuryakyn Magnum Standard mirrors
Saddlebag trunk liner kit and saddlebag kit
LEDGlow lighting
Digital Guard Dawg
kkent66 is offline
post #7 of 43 (permalink) Old 03-06-2014, 02:13 PM
CrossRoads's Avatar
How big is that box?
post #8 of 43 (permalink) Old 03-06-2014, 05:57 PM
you should check I have seen apps that will open your garage door
post #9 of 43 (permalink) Old 03-06-2014, 07:14 PM
Judge Redd's Avatar
The apps I'm seeing so far are bluetooth- and seems they require additional hardware, a bluetooth receiver, etc. In fact- in many cases- the app itself is not mandatory for it to work.
The question I have is how is the opener pairing is affected/ limited by other active BT connections like Phone-Sena. Phones typically do not have multipoint BT, so this makes me wonder if terminating that Phone-Sena pairing is required prior to using the opener app. If yes- (which strikes me as likely) you then have to use the phone menus to pair the opener? Now-- if the app automatically and quickly switched the pairing over for you- I guess that solves all that. Now you just have to have fingerless or smartphone compatible gloves to use it..
Anyone using this type of setup confirm? If I'm anywhere close to right-That Mo door rig looks pretty enticing to me.
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #10 of 43 (permalink) Old 03-06-2014, 07:54 PM
zer0space1's Avatar
I've got the flash2pass on both of my bikes and they work great. The trick is to mount the transmitter where there is not a lot of Metal between it and the receiver unit in your garage.
On the Victory it is mounted in the top half of the headlight bucket. On my other bike it is under the headlight and just above the bottom of the triple tree of the fork. Flash high Beams twice and door works every time.
zer0space1 is offline
