Got my Heli bars, but need help with cruise control issue - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 03-08-2014, 05:00 PM Thread Starter
MTVic's Avatar
Default Got my Heli bars, but need help with cruise control issue
Drove to Daytona today and got my Heli bars installed. LOVE THEM. However.... getting close to home I went to put on my Cruise control. Nada, zip, nothing. No lights. Got home took switch apart on handlebar, don't see anything torn loose, but hard to see in the bugger. Any more ideas would be gratefully as I don't want to ride 300 more miles tomorrow to try and get it fixed!
Mike
FORMERLY 2012 Black XC Tour
2016 Honda NM4
2014 Honda CTX 700 dct
MTVic is offline
post #2 of 5 (permalink) Old 03-08-2014, 05:34 PM
pull faring and start tracing wire for a pinch or un hooked.
Go to fuses and check them
post #3 of 5 (permalink) Old 03-08-2014, 05:40 PM Thread Starter
MTVic's Avatar
Damn, I was hoping not to which is why I had them install the bars and pull my fairing. Think I can reach the wires just pulling the head light?
Where is the fuse?
Mike
2016 Honda NM4
MTVic is offline
post #4 of 5 (permalink) Old 03-08-2014, 06:59 PM
luvmyride's Avatar
You don't have to pull the whole fairing to check around in there.
If you have never had the front outer fairing off, it's no big deal.
Once you pop out the headlight, you only have 4 screws on each (one under each speaker grill). Pull out from below the headlight opening and then up and out at the top (I find removing the windshield helps to release the upper clips), and it's off. Hopefully it's something obvious and you'll save a trip back.
Shouldn't take more than 10-15 minutes to get it off.
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #5 of 5 (permalink) Old 03-08-2014, 09:04 PM
Encmerk's Avatar
Mtvic,
You need to run the cruis control diagnostics out of the last chapter of service manual. Dollars to doughnuts your throttle close switch needs to be adjusted if you connected all wires up right. I had similar issues after doing 2" pullbacks a few weeks ago.
Master Sergeant, USMC Retired
2002 HD Sportster 1200 Custom -sold
2013 XCT Boardwalk Blue picked up 1/21/2014
Vance and Hines hi output slip-ons
Lloydz hi-flow air filter
PCV w/AT
Lloydz ATS @ +4
CrossRoads HID's Hi and Low
Havelock, NC
Encmerk is offline
