Cobra Power Tuner disappointment - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 03-09-2014, 06:59 PM Thread Starter
BigMike45's Avatar
Default Cobra Power Tuner disappointment
Time to purchase a PC-V! I can't take anymore of the backfiring and popping during upshifts and deceleration! I have tried everything from adjusting the internal pot on the inside of the unit and connecting/disconnecting O2 sensors on the Cobra Power Tuner. What a disappointment! It worked great on my Suzuki M109.
2013 Black Victory Cross Country Tour
21" Magnum rim
Arlen Ness beveled shifter
Arlen Ness beveled heel shifter
Arlen Ness beveled brake arm
Arlen Ness shifter/brake pegs
HID High/Low
Lloyds timing wheel
Lloyds air filter
Arlen Ness Big Honkers
Custom Tribal graphics
Madstad shield
USN/LCDR LDO
BigMike45 is offline
post #2 of 5 (permalink) Old 03-10-2014, 03:42 AM
If you can; try to get the Auto Tune unit that goes with it so you never have to worry about tuning your bike again. You might want to put some cams in someday or change exhausts. The Vic motor does tend to pop now and again no matter what we do but it can be minimized. The Lloydz timing wheel was also a big improvement on my 11 XC so I'm glad you already have that.
post #3 of 5 (permalink) Old 03-10-2014, 07:21 AM Thread Starter
BigMike45's Avatar
Thanks Bob, I think I will get both units. Hey I got my heat shields and they are great! Good quality! I added a little bling to mine, used some chrome door trim around the edge. I will upload a pic tonight.
Mike
21" Magnum rim
HID High/Low
Lloyds timing wheel
Lloyds air filter
Madstad shield
USN/LCDR LDO
post #4 of 5 (permalink) Old 03-10-2014, 10:17 AM
post #5 of 5 (permalink) Old 03-11-2014, 12:39 PM
Squatch's Avatar
Hey Shipmate,
When you get the PC-V call Rylan at the Vic Shop for a map to get you started... I used one of his maps on mine without an Auto Tune and it worked great. KMC and TVS have a pile of tunes from various Dyno runs. Tell them what mods you have and I will bet dollars to doughnuts they have a tune for you that is real close. Save the $300+ for a dyno run when you get your cams.
Squatch
USN/USCG Vet
2013 Cross Country Tour
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
D&D wrapped/RPW baffles
Touring Cams
124 hp/119#ft
A country that forgets it's defenders, will itself soon be forgotten
Squatch is offline
