Radio-Bluetooth - Victory Forums - Victory Motorcycle Forum
post #1 of 17 (permalink) Old 03-11-2014, 09:54 AM Thread Starter
New Member
Default Radio-Bluetooth
Good morning all. Need a little help if possible. I have a 2011 XC with stock radio. I recently purchased the Sena SMH10 bluetooth unit for my helmet so I could connect to my phone, talk to other riders, etc. My question is---is there something that I can hook to my radio to make it bluetooh---so I can hear it thru my Sena unit ? Right now when I am on the interstate or have a lot of wind I listen to Pandora on my phone. It works really good except that Pandora has a tendancy to cut off after awhile and then I have to pull over and start it up again. There's got to be a way that I can make my radio bluetooth so I can listen to it thu the Sena. Thanks in advance for your help.
rich49 is offline
post #2 of 17 (permalink) Old 03-11-2014, 10:01 AM
CrossRoads's Avatar
Good morning. Have a looksie at this gizmo: http://www.revzilla.com/motorcycle/s...eo-transmitter
CrossRoads is offline
post #3 of 17 (permalink) Old 03-11-2014, 12:39 PM
bnhender's Avatar
If you listen to a particular radio station, there are several phone apps that stream radio stations as well. TuneIn Radio works very well for me.
___________________________________
Bill
2012 Cross Roads (Sunset Red)
Stage 1 flash
Lloydz Air Filter
Lloydz Idle Control Valve
Lloydz Adjustable Timing Wheel
Freedom Performance True-Dual Exhaust
VM1-DR cams
O2 Sensors disconnected
21" Adrenaline Front Wheel
Cee Bailey 24" windscreen w/ lowers
Tachometer
Small Bullet Light Bar
LED Headlight
Grasshopper driver backrest
Victory passenger backrest
Chrome saddlebag rails
2017 Octane
Shorty pipes
Navasota, TX
bnhender is offline
post #4 of 17 (permalink) Old 03-12-2014, 06:27 AM Thread Starter
New Member
Thanks Crossroads, I will look into that unit. Just have to figure out how to connect it to the radio. I do have an idea. Bnhender, as for local radio stations, they all pretty much suck. When I'm in my truck XM is always on. I am going to Montgomery this weekend to visit my son and his family. Will get to spend time with the twin grandbabies. My son is going to help me install new speakers in the bike, and hopefully I can finally wire up one of my portable XM players. But I would still like to be able to listen to the radio/XM thru my Sena headsets. Thanks for the replies !!
rich49 is offline
post #5 of 17 (permalink) Old 03-12-2014, 06:32 AM
bnhender's Avatar
Enjoy the family time. On the phone app, I believe you can grab any station and they also have specific ones for the app...it is certainly not a solution for XM though.
Ride safe.
Bill
Stage 1 flash
Lloydz Air Filter
VM1-DR cams
Tachometer
LED Headlight
2017 Octane
Shorty pipes
Navasota, TX
bnhender is offline
post #6 of 17 (permalink) Old 03-12-2014, 08:53 AM
Term's Avatar
Victory makes a Sena bluetooth dongle, I would assume that would work on your XC. Part # 2878916
2013 Vision Sunset Red - Stage 1 exhaust, VictoryHID Cyclops
2004 Kingpin - Traded
Term is offline
post #7 of 17 (permalink) Old 03-12-2014, 01:13 PM
If all a person wanted to do was play music from an Android phone through the stock XC stereo system, is there anything else required other than this bluetooth dongle? Is there an open connector inside the fairing to plug this thing in?
2012 Cross Country -
--Atom Bombs
--Lloydz timing gear
--Lloydz air filter
--Power Commander
SOLD -- 2007 Kingpin Tour - Bassani 2>1's - The Vic Shop's 100/6 hop up kit
JFeisty is offline
post #8 of 17 (permalink) Old 03-12-2014, 01:32 PM
Term's Avatar
On my VV there is a harness that you plug the dongle into under the trunk. Not sure where on an XC it is, but I assume it works for an XC as well. The dongle doesn't allow you to play music through your radio from a phone. It just transmits what is playing from your radio to the Sena headset. On my VV there was an audio plug in the glove box. If I had an android phone I would just select AUX and plug the stereo plug in the glove box into the phone. I have an IPhone so I replaced the audio plug with an IPhone harness.
If you want to play music from your phone through your stereo the dongle won't help.
Term is offline
post #9 of 17 (permalink) Old 03-12-2014, 01:44 PM
Ahhhh, ok. This does the opposite of what I'm looking for. thanks.
--Atom Bombs
--Lloydz air filter
--Power Commander
JFeisty is offline
post #10 of 17 (permalink) Old 03-12-2014, 04:20 PM
Encmerk's Avatar
JFeisty,
Do you own a smartphone? Are you willing to pay XM $3 more dollars a month? Do you have a big data plan? If you answered yes to all 3, just use the xm radio app and stream your XM into Bluetooth helmet.
Master Sergeant, USMC Retired
2002 HD Sportster 1200 Custom -sold
2013 XCT Boardwalk Blue picked up 1/21/2014
Vance and Hines hi output slip-ons
Lloydz hi-flow air filter
PCV w/AT
Lloydz ATS @ +4
CrossRoads HID's Hi and Low
Havelock, NC
Encmerk is offline
