Heated Grips on XCT: Bike Must be Running? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 03-18-2014, 09:40 AM Thread Starter
wspollack's Avatar
Default Heated Grips on XCT: Bike Must be Running?
Anyone know whether the heated grips on an XCT require that the engine is actually running -- as opposed to just the key in and turned to run -- in order to work?
I'm putting things back together after taking off the dash, etc., and testing things before I put the fairing on. The grips don't seem to be warm, at least not much, and I don't feel like firing up the bike in my cold garage. Yep, I reconnected the three wires to the dash switch before putting the dash temporarily in place. Thanks.
Cheers,
Bill P.
wspollack is offline
post #2 of 6 (permalink) Old 03-18-2014, 10:10 AM
Bama's Avatar
I've noticed mine take a while to heat up, maybe two minutes to start feeling it. I don't know 100%, but they are strictly electrical, once switch is on they should heat. Seems like when I put my inner fairing back on, I tested mine also before "final" fit and they heated without engine running, I'm almost positive I did. Could be a fuse somewhere, try leaving switch on for two or three minutes.
2013 XCT Sunset Red
Lloyds High Performance Air Filter
Lloyds Adjustable Timing Gear +4
Strip Removed
O2's Unplugged
Vance & Hines
Fastlightsleds
Tank Slapper Paint Protection 3M Kit
Rockford Fosgate PBR300X4
Kicker 6 1/2" up Front
Kicker 5 1/4" in Trunk
Inner Fairing, Trunk Speaker Pods Hydrographic Dipped in Houndstooth.
KlockWerks Windshield
Gen 4 AFR+Fuel Controller
Bama is offline
post #3 of 6 (permalink) Old 03-18-2014, 10:39 AM
gamewarden's Avatar
When I put mine on 2 years ago in my basement I thought the same thing that they would not heat up without bike running. Once I started the bike everything worked great. They may have worked without running but I could never quite feel the heat. I think you are fine.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #4 of 6 (permalink) Old 03-18-2014, 12:10 PM
Could they run directly off the stator to take load off the battery? This is simply a guess on my part... That would explain why they don't seem to heat up until the bike is running.
Or, you just didn't wait long enough!
post #5 of 6 (permalink) Old 03-18-2014, 12:57 PM
with just the key on you should feel a slight bit of warm. Keep in mind its only getting 12v or less once the bike is running you'll feel the heat in about a minuets time.
If you feel slight heat you did good work
post #6 of 6 (permalink) Old 03-18-2014, 01:08 PM Thread Starter
wspollack's Avatar
bama, gamewarden, broggyr, and vj: thank you all very much for your help and suggestions.
I had to run some (car) errands, got home, and as it was a whopping 37 degrees here (but still some snow and lots of salt on the roads) I decided to let the cold into the garage, and fire up the bike. And all is well!
So, the definitive answer is: I don't know. That is, after a minute or two -- with the engine running, and the grips on low -- I got a goodly amount of heat. I let that stabilize a few minutes, and switched to high, where I got a goodly amount of additional heat. Playing around this morning, with just the ignition circuit on, I waited for maybe five minutes, and if there was any heat coming off the grips, it was sufficiently low that I wasn't sure whether I was imagining it. BTW, I have the bike hooked up to a smart charger, so the battery was/is in tip-top condition.
So, basically, what I'm saying now is what gamewarden said above. Anyway, all's well that ends well, and thanks again, everyone.
Cheers,
Bill P.
