Removing valve covers. - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 03-21-2014, 08:30 PM Thread Starter
Default Removing valve covers.
I have a 2010 XC and have chrome valve covers. I'd like to remove them and have them powdercoated. Is there anyway to remove them without removing the entire engine? I've been told the front one can't be removed without removing the entire engine. Any ideas? Thanks!
Wyckedjester is offline
post #2 of 6 (permalink) Old 03-21-2014, 08:57 PM
Somewhere on the forum is a step by step on changing cams on a cross country. They explain how to get the valve covers off and swap cams without pulling the engine.
Riding a 2012 Imperial Blue Cross Country
Creek_IP is offline
post #3 of 6 (permalink) Old 03-21-2014, 09:42 PM
Hemidan's Avatar
start reading around page 14
if you go this far,you might as well replace the cams....
https://docs.google.com/file/d/0B95B...fUQ/edit?pli=1
2010 CR - D&D pipes unwrapped / Lloydz Performance Cams / Lloyd'z Idle Air Valve / Lloydz Adjustable Timing System / Lloydz Hi-Flow Air Filter / PCV w/AT / Vintage Mustang Seat w/backrest / Lock Ride Passenger Backrest / Powerlet Handlebar Outlet / Lay down License Bracket / Adjustable Drop Bracket
Avon Velvet Air Cushion Gatlin Grips/DERBY COVER & CAM COVER SET/Beacon LED Headlight Black
Phase 7 L.E.D. 4-1/2" Passing Lamps/Sabertooth Taillight Accents
Hemidan is offline
post #4 of 6 (permalink) Old 03-22-2014, 07:34 AM Thread Starter
Guess I'll be replacing the cams then!! ;-)
2013 Suede Nuclear Sunset Cross Country
Vicbaggers Tarzanz handlebars
Thrush modded exhaust
Saddlebag rails
Avon grips and Avon shifter pegs
Kuryakyn Liberator highway pegs with stirrups
and much more
See this post for more details.
post #5 of 6 (permalink) Old 03-22-2014, 08:21 AM
I like the way you think lol
post #6 of 6 (permalink) Old 03-22-2014, 08:27 AM
Hemidan's Avatar
me too....
Hemidan is offline
