Cross Roads floorboards - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 09-09-2011, 07:19 PM Thread Starter
Garion12's Avatar
Default Cross Roads floorboards
Let me preface this post with the fact that I am not bragging here.
Now here is the situation: I have been dragging the holy hell out of my floorboards while riding and am now actually starting to worry about the thickness of them. Has anyone here actually worn through their floor boards? How much abuse can they actually take? I have not taken off the rubber top to look but after feeling where they are wearing it doesn't seem so thick to me.
Any input?
2010 Cross Roads
Lloydz Air Filter
Lloydz Slip on Exhaust
Lloydz Timing Wheel 8*
LLoydz VM1-HPT Cams
Lloydz reflesh 6500 rpm
Dyno tuned by KMC 123 hp 121 tq
Garion12 is offline
post #2 of 8 (permalink) Old 09-09-2011, 07:40 PM
TN Rider's Avatar
Send a message via Skype™ to TN Rider
I wouldn't worry about it too much. The rubber cap on the floorboards is in there pretty tight. I haven't had the chance to hit the hills too much since I bought my XC, but I had a Suzuki Volusia with floorboards that I was wearing up into the rubber (had already worn off the chrome lip around the side) and it still didn't have any problems with slippage.
Since they wear from the edge in, you can get a lot of life out of them, even after you start wearing into the rubber.
PS The more of the floorboard, you wear off, then you can hold a lower angle in the corners!
PPS I'm planning to hit the Tail of the Dragon next weekend (I'm assuming that's where you've been doing your draggin)....you up?
2011 Cross Country Ness Edition #175
Stage 1 Flash
VM1-DR cams
PC-V Controller
Underdrive pulley
Lloydz High Flow Air Filter
Big Gonzo mufflers
iPod adapter
Hidden antenna
Polk MM6501UM w/ RF PBR300x2 amp up front
JL M10IB5-SG-TB sub w/ RF M750-1D amp in the saddlebag
Madstad brackets & Dark Smoke Shield
LED Headlight
Rider Backrest
Passenger Backrest w/ Luggage Rack
Arlen Ness Retro Floorboards
Chromed Passenger Floorboards
2001 Suzuki Volusia (traded-in)- My first bike
TN Rider is offline
post #3 of 8 (permalink) Old 09-09-2011, 08:12 PM Thread Starter
Garion12's Avatar
Thats a good point about the lower lean angle.
Yes, I might have been that way a few times. I think what is doing the most damage though is that I watched the youtube videos of the victory police bikes dragging at slow speeds and wanted to try it. Now I just go out into the cul-de-sac and ride circles dragging the boards. If you haven't tried it, you should; it's soooo much fun!!!
My wife actually took a video of it today on her iphone. If I ever get it off her phone I'll put it onto youtube and post a link.
2010 Cross Roads
Lloydz Air Filter
LLoydz VM1-HPT Cams
Garion12 is offline
post #4 of 8 (permalink) Old 09-09-2011, 09:10 PM
PhilC64's Avatar
A good friend with a Tig Welder can add more metal on as time goes by. Scrape away!
2015 XCT - Flying lounge chair
PCV, ATS +4, Lloydz filter, VM1-HPT cams, and Freedom True Duals.
2004 King Pin - 100 cid Big Bore, Ness Intake, Victory Performance Exhaust
2010 XR - Road toy
PCV, ATS +4, Lloydz filter, VM1-DR cams, and Freedom True Duals - traded
Cam Swap write up for X Series bikes:
https://docs.google.com/open?id=0B95...YW1XVXFpeU9fUQ
PhilC64 is offline
post #5 of 8 (permalink) Old 09-10-2011, 12:16 AM
bryman's Avatar
They should be able to take some abuse before wearing through. Besides, that part is only about $50 in black, so they're pretty painless to replace.
Current Bike: 2011 Victory Cross Roads - Crimson
Options and Accessories:
Victory: Stage 1 / Forged Bars w/pegs / Medium Windshield / Lowers / Hard Bags w/ Guards / Passenger Backrest / XC Passenger Floorboards / Heated Grips / Unlocked Speedo w/ temp probe
Other: Signal Dynamic LED Plate frame w/BackOff XP / Clearwater Glenda LED Lights / 3BRPowersports USB in-bag power port / Utopia police backrest w/quick-out / D&D Boss slip-ons (569-12F)
bryman is offline
post #6 of 8 (permalink) Old 09-10-2011, 11:16 AM
The actual metal on the board is not very thick, but the rubber is fairly thick rigid material. What psi are you running in the shock, just wondering?
kfxgeenie is offline
post #7 of 8 (permalink) Old 09-11-2011, 02:33 PM
You might want to take a look at what they are actually dragging on the VPM bikes. http://www.victorypolicemotorcycles.com/products.html Go down about mid page, left column.
Billy
2014 XC
2006 Vegas 8 Ball
2014 Harley FLHTP (Keeping service techs busy)
Billyrides is offline
post #8 of 8 (permalink) Old 09-11-2011, 06:03 PM
saddlebag's Avatar
Mine doesn't have any crash bars, so I have been a little hesitant to get too carried away. It does look like fun though.
saddlebag is offline
