Air box seal EU - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 03-28-2014, 11:12 AM Thread Starter
mika66's Avatar
Default Air box seal EU
Hello my friends.
As many times i have read and look pics about removing air box seal and how easy job it is.
Now i need to change air filter, good time to do seal removing in same and that i did.
Lot more sucking noise after removing, but check pics, there was some suction "snoute" with Polaris EU texts. I toss that and seal away.
As i said, more noise but i donīt care if there is any improvement in HP/TQ, but canīt test it in road few days.
Cross Roads 2012
mika66 is offline
post #2 of 4 (permalink) Old 03-28-2014, 11:54 AM
yes you will pick up some power and you might lean the motor out to much. Most will un-hook the 02's to give the motor more fuel witch means more power
How the belt holding up
post #3 of 4 (permalink) Old 03-28-2014, 01:16 PM Thread Starter
mika66's Avatar
Hi,
I hope serious change, but you can always hope
i don`t 100% agree to un-hook o2.
Ecu use o2 data to control fuel/air ratio. So it could be better have programmable O2 sensor.
Belt is "fine", i just update belt issue:
https://www.victoryforums.com/showthread.php?t=20338
Cross Roads 2012
mika66 is offline
post #4 of 4 (permalink) Old 04-01-2014, 12:26 PM Thread Starter
mika66's Avatar
Ok, today i make some road tests.
Clearly more torque in low RPM. Good.
More fuel. Bad.
More suction noise. I don`t mind.
Nothing what i can say in higher RPM. Need more testing.Today it starts to snowing so it was little too short drive.
Few pics from here:
https://www.victoryforums.com/showthr...866#post790866
Cross Roads 2012
mika66 is offline
