Auxiliary cable/ no hand controls? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 03-30-2014, 10:45 PM Thread Starter
Default Auxiliary cable/ no hand controls?
I just installed a auxiliary extension kit and auxiliary audio connecter for my victory cross country. After turning the bike on to test it i realized i couldn't run the ipod through hand controls like i want to. I noticed on the extension where it ends up next to the saddle bag that there is 2 connecters while the audio connecter with the rubber grommet only has 1 connecter. So one connecter us not being used...does that matter? And I can't even find a ipod mode on my dash. I desperately need help narrowing down what could be wrong. Any help is greatly appreciated!!!
BoutietteXC is offline
post #2 of 6 (permalink) Old 03-31-2014, 07:29 AM
Pacman's Avatar
Im not sure about the wiring. On my 13 xc I go thru the modes until AUX appears on the stereo. Thats the mode I use to play the iPod thru the stereo.
2013 Victory Cross Country.
Lay down plate holder..installed 3-10-2014
1.5 lowering kit installed 3-23-2014
Gustaffson +1 Dark smoke Installed 4-02-2014
heel shifter Installed 3-28-2014
iPod connector installed 3-6-2014
Driver backrest 8-15-2014
Amp
trunk 7/20/2014
Drilled 6 1/2 holes in pipes 7-2014
Pacman is offline
post #3 of 6 (permalink) Old 03-31-2014, 07:41 AM
gamewarden's Avatar
Hope I am understanding correctly. There should be 2 white connectors under the fairing one is a 3 pin the other 4 pin both need to be used. If one is used all you get is volume control. My Ipod is in the left lower but the connections are the same. It does not sound like you have the extra hundred dollar hook up that attaches to the end on the aux cable, see catalogue book.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #4 of 6 (permalink) Old 03-31-2014, 08:30 AM
gamewarden's Avatar
It looks like you have the accessory cable not the Ipod hook up. Look on page 35 of the accessory catalogue to see the difference. The cable is for all different players and you get volume only where as the Ipod hookup does everything.
post #5 of 6 (permalink) Old 03-31-2014, 09:12 AM Thread Starter
I think your right saying I only have the accessory cable and not the ipod hookup I'll have to do some quick research if that's the cable I bought. Thanks for the help!
post #6 of 6 (permalink) Old 03-31-2014, 10:05 AM Thread Starter
Yupp I just bought the wrong audio connection. I didn't buy the ipod one with ability to be controlled through the handlebar. I will buy one this weekend. Thanks for the assistance
