Top nut on Passenger Pegs - Victory Forums - Victory Motorcycle Forum
post #1 of 17 (permalink) Old 03-31-2014, 11:55 AM Thread Starter
sep1006's Avatar
Default Top nut on Passenger Pegs
Does anyone know what size that is? My biggest thinwall socket doesn't fit it and I'm looking to remove the passenger pegs. I ride solo 99% of the time and those things are but ugly. They really stand out and in my opinion take away from the looks of the bike.
2014 VIC XC PEARL WHITE
STAGE 1 UPGRADE W/K&N FILTER
BLACK TRI-OVAL EXHAUST W/CHROME TIPS
BLACKED OUT LENS'
LOWERING LINK ( DROPPED 2" )
CUSTOM PINSTRIPING
PAINTED OUTER CHIN SPOILERS
GUSTAFSON EUROFLIP +2"[/B]
RICZ LAYDOWN PLATE
DEBADGED AND REFLECTORS REMOVED
O2 SENSORS DISCONNECTED
LLOYDS TIMING WHEEL
SHORTY ANTENNA FROM MINI-COOPER
21"WHEEL KIT FROM WD
BUNCH OF NESS ADD-ONS
sep1006 is offline
post #2 of 17 (permalink) Old 03-31-2014, 12:08 PM
tkirby16's Avatar
Default 24mm
I didn't have a 24mm but I used a 15/16 and it worked when I swapped mine out.
Bulk
USN Submarine Veteran
2013 Victory Cross Country
PCV, Bassani Exhaust, HMD Gorilla Bagger Bars, Pass Floorboards, Pass Quick Disconnect Backrest, HID kit, Victory Derby/Cam covers, mirrors, Lloydz Timing Wheel and Lloydz Air Filter, Avon grips and Quarter Turn Throttle ring, RICZ laydown plate!!
Spring Hill, TN
tkirby16 is offline
post #3 of 17 (permalink) Old 03-31-2014, 02:05 PM
sparkyo1's Avatar
can you just remove the nut, remove the brackets, and be done? put the nut back on? I agree...they are butt ugly and I ALWAYS ride alone!
2013 XC ANTI-FREEZE GREEN
Tomball Tx.
sparkyo1 is offline
post #4 of 17 (permalink) Old 03-31-2014, 02:54 PM Thread Starter
sep1006's Avatar
Well you have the nut on top and the allen head on the bottom to remove the whole bracket. I can see some things behind the bracket so I'm not quite sure what having everything exposed is going to look like. But if it looks bad I will come up with a way to cover it up or make it look not so obvious.
BLACKED OUT LENS'
CUSTOM PINSTRIPING
RICZ LAYDOWN PLATE
LLOYDS TIMING WHEEL
sep1006 is offline
post #5 of 17 (permalink) Old 03-31-2014, 08:51 PM Thread Starter
sep1006's Avatar
tkirby - did you take yours totally off or just replace them? Also if you removed them did you have to take the exhaust shield off on the right side?
BLACKED OUT LENS'
CUSTOM PINSTRIPING
RICZ LAYDOWN PLATE
LLOYDS TIMING WHEEL
sep1006 is offline
post #6 of 17 (permalink) Old 04-01-2014, 12:51 AM
tonygiotta's Avatar
The left passenger peg bracket also serves as the stop for the kickstand when it is in the up position. The little nub on mine got hit by a rock and snapped off which made it a real pain to get the kickstand back down. Not sure if removing the bracket altogether would create an issue or not. Could swear I've seen a replacement piece to bolt on in place of the passenger peg assembly, but can't remember where off hand.
'04 Kingpin - Blue w/ Tribal Flames (sold)
'12 Cross Country - Imperial Blue
tonygiotta is offline
post #7 of 17 (permalink) Old 04-01-2014, 12:56 AM
tonygiotta's Avatar
Ahh, here we go... Arizona Victory.
Passenger Peg Eliminator
Still not sure if they're actually necessary.
post #8 of 17 (permalink) Old 04-01-2014, 07:05 AM
tkirby16's Avatar
Default Pass Floorboards
I purchased the passenger floorboards for my wife. Not sure why these aren't standard. The left side is easy. The right side is a mutherfu*%er. You have to basically take the exhaust system off. The way the lower attachment point goes in between the exhaust manifold that splits to the left side makes it so you cannot get it out. I have the directions from the floorboards, and was positive I could figure out an easier way. I have yet to do that!!!!! I put the left side back on, until I can take my bike damn near apart to get right one installed. CRAZY!!!!
Bulk
Spring Hill, TN
tkirby16 is offline
post #9 of 17 (permalink) Old 04-01-2014, 07:07 AM
tkirby16's Avatar
If you want a copy of the directions from the floorboards, message me your email and I will bring in and scan them to you.
Bulk
Spring Hill, TN
tkirby16 is offline
post #10 of 17 (permalink) Old 04-01-2014, 07:30 AM Thread Starter
sep1006's Avatar
Thanks for the input and offer. Next time I get a chance I'll look at it closer. If I have to take the whole damn exhaust off then I will wait.
BLACKED OUT LENS'
CUSTOM PINSTRIPING
RICZ LAYDOWN PLATE
LLOYDS TIMING WHEEL
sep1006 is offline
