Upper and Lower Saddlebag Filler Panel - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 04-02-2014, 12:18 AM Thread Starter
sand man's Avatar
Default Upper and Lower Saddlebag Filler Panel
Just order upper and lower saddlebag filler panel from Witchdoctor. Anyone have these? How was install? Any tips? Did you add a rubber strip between fender and filler panel?
2011-12-13 Pres. Abilene Roadriders
His: 2015 Victory Cross Country Tour
Well Equiped
Hers: 2015 Gunner
Nicely Equiped
sand man is offline
post #2 of 6 (permalink) Old 04-02-2014, 01:25 AM
HammerNV's Avatar
Install was fairly straight forward. I taped off the fender before as not scratch it. I also pop riveted the lowers instead of bolting with the supplied bolts.
I'm thinking maybe a bulb type weather stripping on the underside might work and have a clean look.
2013 XC Sunset Red Black Out
Lloydz AF,VM1 cams & timing wheel, PCV&AT,FMB Bars,WI Mirrors,VHID's,BOAB Slip-on's, Vic Backrest & BOAB Rack, arc audio amp, Hawg Wired 6.5's. Madstad, plastidiped KW flip, RJ cheese wedges, Cree led's, CSG Frt signal relocation.
HammerNV is offline
post #3 of 6 (permalink) Old 04-02-2014, 05:51 AM
DirtyDan's Avatar
I have mine but have not installed them yet. Just been to busy. I like the rivet idea. I bought clear door edge molding that I'm gonna try. I have the color matched ones.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #4 of 6 (permalink) Old 04-02-2014, 08:59 AM
HammerNV's Avatar
Mine are plasti dipped. I did as a temporary thing but I like the look.
HammerNV is offline
post #5 of 6 (permalink) Old 04-02-2014, 11:39 AM
What kind of mirrors are those? I saw WI in the sig, but I don't know who that is.
Thanks
DaveReed is offline
post #6 of 6 (permalink) Old 04-02-2014, 12:58 PM
HammerNV's Avatar
Wicked Image
HammerNV is offline
