Moved Air Shock hose fitting - convenience - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 04-04-2014, 05:04 PM Thread Starter
Smile Air Shock Hose extension kit - Convenient and easy Installation
I sometimes ride with GF as passenger and I did not like repeatedly taking off side cover to change suspension shock psi and risking breaking one of the the plastic nubs that hold the side cover on. I had an air shock hose extension connection rated to 200+ psi made for me by a commercial hose manufacturing business with so that I could move it out from behind the side cover to access easily. Fits exactly and it is
Convenient, Quick and Easy to use. Made in America. Includes how to install instructions and 2 tie wraps.
Made some more in case anyone is interested in buying one - Posted in Marketplace section.
2012 Cross Country Tour - VroomHilda
Dobeck EJK Gen3 Fuel Tuner with Innova AF meter
Vic K&N knock off Air filter
Lloyds Timing Wheel +4
Relocated Air Shock fill hose
WD SkidPlate reinforced
Hyper running/brake lights
Garmin GPS
Existential Secular Humorist with warrior Buddhist leanings
*Rider/Owner continuous since 1973 - 877,000+ miles USMC R
SemperVee is offline
post #2 of 6 (permalink) Old 04-04-2014, 07:23 PM
wspollack's Avatar
Victory should have relocated the fill valve, especially once they started making the Tour, which has both saddlebag guards and passenger foot-board supports less than an inch away from, and in the way of removing, the right side cover.
There were some variations of this mod started by MTVic about four months ago -- see https://www.victoryforums.com/showthread.php?t=59042 , which wound up on the left side -- and me -- see my write-up at http://www.billanddot.com/shock-valve-relocation.html , which wound up similar to your work, except that I drilled through the side cover and added a new Schrader valve.
In any case, nicely done.
Cheers,
Bill P.
wspollack is offline
post #3 of 6 (permalink) Old 04-05-2014, 07:35 PM Thread Starter
Only have one more Air Shock Hose extension left..
Going, Going.......
Garmin GPS
post #4 of 6 (permalink) Old 04-05-2014, 08:29 PM
PM sent, have any left?
2012 Victory Cross Country Tour, Sunset Red.
Parts added to make her louder, faster and more mine.
Stage 1 filter and pipes, Lloydz VFIII & ATW.
Clearwater Darla, LED GLO, emergency lights and siren.
Bushtec hitch and harness, Kompact Kamp trailer.
ChuglyXJ is offline
post #5 of 6 (permalink) Old 04-07-2014, 09:28 AM Thread Starter
Gone...
The extra Air Shock Hose Extensions all sold over the weekend so it has proven to be a good idea and popular item.
Garmin GPS
post #6 of 6 (permalink) Old 04-11-2014, 01:12 AM Thread Starter
I had a few more made up and ready to ship.
Garmin GPS
