tire rub on decent bump, lowered 1 1/2" - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 04-10-2014, 06:15 PM Thread Starter
dtmmil's Avatar
Default tire rub on decent bump, lowered 1 1/2"
anyone else have any rubbing? im lowered 1 1/2" 15psi in the shock , im just shy of 200 lbs, hit a decent bump/ripple in the road today and got a slight wiff of rubber, got home and looked up in the fender and looks like the tire just clipped the very rear of the tail of the frame. i added 5psi of air(20 now) but what about those of you with lowered bikes?
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #2 of 9 (permalink) Old 04-10-2014, 06:22 PM
what is the measurement on bike with it straight up and down from bottom of motor to ground?
What side of the bike rubbed?
Did the otter lip on the tire hit or did the side wall hit?
How much air in tire?
post #3 of 9 (permalink) Old 04-10-2014, 07:37 PM
Hemidan's Avatar
What should the shock pressure be at?
normal solo riding?
2-up riding?
Lowered 1.5" solo?
Lowered 1.5" 2-up?
2010 CR - D&D pipes unwrapped / Lloydz Performance Cams / Lloyd'z Idle Air Valve / Lloydz Adjustable Timing System / Lloydz Hi-Flow Air Filter / PCV w/AT / Vintage Mustang Seat w/backrest / Lock Ride Passenger Backrest / Powerlet Handlebar Outlet / Lay down License Bracket / Adjustable Drop Bracket
Avon Velvet Air Cushion Gatlin Grips/DERBY COVER & CAM COVER SET/Beacon LED Headlight Black
Phase 7 L.E.D. 4-1/2" Passing Lamps/Sabertooth Taillight Accents
Hemidan is offline
post #4 of 9 (permalink) Old 04-10-2014, 08:11 PM Thread Starter
dtmmil's Avatar
it rubbed straight up on the rear of the frame. so only when compressed, plenty of room on the sides. i will have to get a height measurement. shock pressure for my weight i think is zero with just me. and it rubbed with me solo, 15 psi, 1 1/2" lowered. and the tire has 38psi, its a stock sized avon cobra.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #5 of 9 (permalink) Old 04-11-2014, 03:54 AM
Default Lowering XC
Tell us more about the lowering link, Adjustable on Solid. and did you check the length prior to putting on if ajustable.
How long has it been lowered
2013 Cross Country Sunset Red
Lloyds Timing wheel set at +4
Lloyds air filter
PCV with auto tune
Witch Doctor slip on
Witch Doctor shifter and rear brake bushings
Adjustable rear link set at 1.5"
Custom Seat cut down 1.5"
Witch Doctor Billet Brake and Clutch leavers
HID headlight
Tour Pack
Passenger back rest
DMacHammer is offline
post #6 of 9 (permalink) Old 04-11-2014, 05:36 AM Thread Starter
dtmmil's Avatar
its the adjustable, yes i checked it i set it to 3/4" shorter then stock. i have about 200 miles on it since i installed this link. if you look up under the fender above the tire you can see the very tail of the frame kinda scoop down. thats what it rubbed.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #7 of 9 (permalink) Old 04-11-2014, 08:30 AM
MTVic's Avatar
More than likely:
The link IS NOT the correct length. measure it and compare to a 1 1/2" fixed link. I measure mine and from center top hole of link to center of bottom hole it is approx. 11 3/8" (probably 11 1/4" since 1/2" equals 1" for lowering, so 3/4" lower than stock 12" = 11 1/4")
Check tire. May actually be taller than a stock, even though rim and width size same. On my old HD I used Continentals because they were "shorter" making bike lower.
Lastly, and probably not the issue, make sure your shock is OK and not leaking oil. My slowly failed and now needs replacing at 14k. I can add 50 lbs and still hit on medium bumps, new shock coming.
Mike
FORMERLY 2012 Black XC Tour
2016 Honda NM4
2014 Honda CTX 700 dct
MTVic is offline
post #8 of 9 (permalink) Old 04-11-2014, 09:36 AM Thread Starter
dtmmil's Avatar
that is how i set it 11 1/4" c to c, shock is good also. and yes my tire is taller then the stock pos dunlop, its about the size it is suppose to be, not shorter like the dunlop. i will try to get a pic of where it rubbed.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #9 of 9 (permalink) Old 04-11-2014, 07:23 PM
Default Lowering XC
I ride two up quite often, around 375 lb plus what's in the saddle bags. The shock is set at 42 lb with no problem. I have not put the tour pack back on cense I Lowered it. Tires are stock cense I only have 7,000 miles on it know.
Lloyds air filter
PCV with auto tune
HID headlight
Tour Pack
Passenger back rest
